Ana içeriğe geç
Logitech G910 Lights Replacement
Neye ihtiyacın var
  1. Logitech G910 Lights Replacement, Lights: adım 1, 1 resimden 1.
    • Unplug the keyboard from the computer.
  2. Logitech G910 Lights Replacement: adım 2, 1 resimden 1.
    • Flip the keyboard and unscrew the 15 back screws. The screws in the palm rest must be unscrewed and the palm rest removed to access the 6 screws at the bottom of the keyboard. (There are 2 lengths of screws the shorter ones are for the palm rest) There are also 2 screws under the nonslip pads of the palm rest.
  3. Logitech G910 Lights Replacement: adım 3, 1 resimden 1.
    • Release the front part using a spudger or flat screwdriver to gently pry. Lift off carefully.
  4. Logitech G910 Lights Replacement, Lift the film: adım 4, 2 resimden 1. Logitech G910 Lights Replacement, Lift the film: adım 4, 2 resimden 2.
    • Gently lift up the plastic film in the top right corner.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
3 Yorum
So what do I do after I take apart my keyboard?
CuddlyZebesian - Yanıt
this guide is currently missing some steps. If you have figured it out, pls edit this guide.
tayola -
Desolder and replace LEDs the size of a grain of sand xD
This is definitely not a job I'd mark as "easy".
squallloire -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 27
Son 30 gün: 107
Her zaman: 6,103
