Giriş
Follow this guide to replace worn-out or damaged feet (also known as skates, glides, slides, or pads) on your Logitech G915 TKL wireless keyboard.
Neye ihtiyacın var
Slide the power switch on the top edge of your keyboard into the OFF position.
Unplug all cables from your keyboard.
Lay your keyboard down with the feet facing up on a clean work surface.
Use the flat end of a spudger to scrape up and remove any chunks of adhesive from the foot recesses.
Remove the new feet from their backing and firmly press them into place.
