Ana içeriğe geç
Logitech G915 TKL Keyswitch Replacement
Neye ihtiyacın var
  1. Logitech G915 TKL Keyswitch Replacement, Keyswitch: adım 1, 2 resimden 1. Logitech G915 TKL Keyswitch Replacement, Keyswitch: adım 1, 2 resimden 2.
    • Remove all of the keycaps on the keyboard.
    • Unscrew the 2mm #00 Phillips screws circled in the picture provided.
  2. Logitech G915 TKL Keyswitch Replacement: adım 2, 2 resimden 1. Logitech G915 TKL Keyswitch Replacement: adım 2, 2 resimden 2.
    • Turn the keyboard around and peel back the Logitech sticker near the top center of the keyboard, as well as the plastic layer underneath.
    • Unscrew the two 2.5mm #0 Phillips screws circled in the picture provided.
    • Remove the backplate by grabbing the notch to the right and pulling up.
  3. Logitech G915 TKL Keyswitch Replacement: adım 3, 2 resimden 1. Logitech G915 TKL Keyswitch Replacement: adım 3, 2 resimden 2.
    • Remove the foam strips shown in the picture provided.
    • Unscrew all the 2mm #00 Phillips screws on the back of the keyboard circled in the picture provided.
  4. Logitech G915 TKL Keyswitch Replacement: adım 4, 1 resimden 1.
    • Remove the casing on the keyboard to reveal the motherboard.
  5. Logitech G915 TKL Keyswitch Replacement: adım 5, 1 resimden 1.
    • Find the corresponding soldering point for the keyswitch you wish to replace.
  6. Logitech G915 TKL Keyswitch Replacement: adım 6, 1 resimden 1.
    • Carefully heat the soldering wire.
    • Place the wire near the keyswitch's solder points so that it can be desoldered by the wire.
    • Insert your new keyswitch in place of the old one.
    • Solder the new keyswitch into place.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Ethan Bedard
635 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-6, Petersen Spring 2023 UMass Dartmouth, Team 3-6, Petersen Spring 2023 üyesi
UMASSD-PETERSEN-S23S3G6
4 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 14
Son 7 gün: 179
Son 30 gün: 904
Her zaman: 29,861
