Ana içeriğe geç
Logitech G915 TKL Volume Wheel Replacement
Neye ihtiyacın var
  1. Logitech G915 TKL Volume Wheel Replacement, Volume Wheel: adım 1, 2 resimden 1. Logitech G915 TKL Volume Wheel Replacement, Volume Wheel: adım 1, 2 resimden 2.
    • Turn the keyboard around and peel back the Logitech sticker near the top center of the keyboard, as well as the plastic layer underneath.
    • Unscrew the two 2.5 mm #0 Phillips screws circled in the picture provided.
    • Remove the backplate by grabbing the notch to the right and pulling up.
  2. Logitech G915 TKL Volume Wheel Replacement: adım 2, 2 resimden 1. Logitech G915 TKL Volume Wheel Replacement: adım 2, 2 resimden 2.
    • Remove the foam strips shown in the picture provided.
    • Unscrew all the 2 mm #00 Phillips screws on the back of the keyboard circled in the picture provided.
  3. Logitech G915 TKL Volume Wheel Replacement: adım 3, 1 resimden 1.
    • Remove the keyboard's casing to reveal the motherboard.
  4. Logitech G915 TKL Volume Wheel Replacement: adım 4, 2 resimden 1. Logitech G915 TKL Volume Wheel Replacement: adım 4, 2 resimden 2.
    • Carefully remove the volume wheel from the device using your fingers.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ekip
UMass Dartmouth, Team 3-6, Petersen Spring 2023 UMass Dartmouth, Team 3-6, Petersen Spring 2023 üyesi
UMASSD-PETERSEN-S23S3G6
4 Üyeler
15 adet Kılavuz yazıldı
2Kılavuz Yorumları
Where tf do you get the scroll bar thing from?
Bit Stream - Yanıt
Did you have any luck?
josesalomonfm -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 27
Son 30 gün: 176
Her zaman: 2,629
