Ana içeriğe geç
Logitech Gamepad F310 Bumpers Replacement
Neye ihtiyacın var
  1. Logitech Gamepad F310 Bumpers Replacement, Case: adım 1, 2 resimden 1. Logitech Gamepad F310 Bumpers Replacement, Case: adım 1, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove all seven 3 mm screws that secure the rear case.
    FixBot'a Sor
    Yorum Ekle
  2. Logitech Gamepad F310 Bumpers Replacement: adım 2, 2 resimden 1. Logitech Gamepad F310 Bumpers Replacement: adım 2, 2 resimden 2.
    • Press along the seams of the controller and gently pull the front and rear case apart.
    • If necessary, use an opening tool to help pry the front and rear case apart.
    • Make sure to open the controller with the front facing down so that the buttons do not fall out.
    FixBot'a Sor
    Yorum Ekle
  3. Logitech Gamepad F310 Bumpers Replacement: adım 3, 1 resimden 1.
    • Separate the front and rear case.
    • There are two side panels on the controller that come apart as well. When putting them back together, they slot into place on the sides of the controller.
    FixBot'a Sor
    Yorum Ekle
  4. Logitech Gamepad F310 Bumpers Replacement, Bumpers: adım 4, 2 resimden 1. Logitech Gamepad F310 Bumpers Replacement, Bumpers: adım 4, 2 resimden 2.
    • Grip the bumper and pull directly up to remove it.
    • Repeat for the other side if necessary.
    FixBot'a Sor
    Yorum Ekle
Sonuç
You're all finished! To reassemble your device, follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Graydon
187 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 19
Son 30 gün: 67
Her zaman: 1,053
