Ana içeriğe geç
Logitech Gamepad F310 D-Pad Replacement
Neye ihtiyacın var
  1. Logitech Gamepad F310 D-Pad Replacement, Case: adım 1, 2 resimden 1. Logitech Gamepad F310 D-Pad Replacement, Case: adım 1, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove all seven 3 mm screws that secure the rear case.
    FixBot'a Sor
    Yorum Ekle
  2. Logitech Gamepad F310 D-Pad Replacement: adım 2, 2 resimden 1. Logitech Gamepad F310 D-Pad Replacement: adım 2, 2 resimden 2.
    • Press along the seams of the controller and gently pull the front and rear case apart.
    • If necessary, use an opening tool to help pry the front and rear case apart.
    • Make sure to open the controller with the front facing down so that the buttons do not fall out.
    FixBot'a Sor
    Yorum Ekle
  3. Logitech Gamepad F310 D-Pad Replacement: adım 3, 1 resimden 1.
    • Separate the front and rear case.
    • There are two side panels on the controller that come apart as well. When putting them back together, they slot into place on the sides of the controller.
    FixBot'a Sor
    Yorum Ekle
  4. Logitech Gamepad F310 D-Pad Replacement, D-Pad: adım 4, 3 resimden 1. Logitech Gamepad F310 D-Pad Replacement, D-Pad: adım 4, 3 resimden 2. Logitech Gamepad F310 D-Pad Replacement, D-Pad: adım 4, 3 resimden 3.
    • Remove the silver 3 mm screw in the middle of the D-pad with a Phillips #1 screwdriver.
    • Remove the D-pad
    • There are 4 buttons that go in the four slots of the D-pad, a spring on one side, and the D-Pad on the other side.
    FixBot'a Sor
    Yorum Ekle
Sonuç
This is how to replace a D-Pad on a Logitech Gamepad F310. To reassemble your device, follow these instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 21
Son 30 gün: 78
Her zaman: 1,167
