Ana içeriğe geç
Logitech Harmony 650 Battery Terminal Replacement
Neye ihtiyacın var
  1. Logitech Harmony 650 Battery Terminal Replacement, Case: adım 1, 2 resimden 1. Logitech Harmony 650 Battery Terminal Replacement, Case: adım 1, 2 resimden 2.
    • Remove the battery cover by applying pressure to the indented area and pushing the cover toward the rear of the device.
    FixBot'a Sor
    Yorum Ekle
  2. Logitech Harmony 650 Battery Terminal Replacement: adım 2, 1 resimden 1.
    • Remove the batteries using the silver pull tab.
    FixBot'a Sor
    Yorum Ekle
  3. Logitech Harmony 650 Battery Terminal Replacement: adım 3, 1 resimden 1.
    • Using a J000 Philips head screwdriver remove the four 5mm screws around the rim of the battery chamber.
    FixBot'a Sor
    Yorum Ekle
  4. Logitech Harmony 650 Battery Terminal Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Remove the small plastic cover beneath the plastic LED housing by using a 3.0 flathead screwdriver and a spudger to pry it off. It is glued to the case. If you are having trouble removing it try applying some heat to loosen the glue.
    FixBot'a Sor
    Yorum Ekle
  5. Logitech Harmony 650 Battery Terminal Replacement: adım 5, 1 resimden 1.
    • Remove the two 5mm screws located underneath the cover using a J000 Philips screwdriver bit.
    FixBot'a Sor
    Yorum Ekle
  6. Logitech Harmony 650 Battery Terminal Replacement: adım 6, 2 resimden 1. Logitech Harmony 650 Battery Terminal Replacement: adım 6, 2 resimden 2.
    • Using a plastic opening tool, pry the case off starting from the top of the device (nearest the transmitter). There are 3 tabs along the side of the case and one at the back.
    • The top led protector plastic cover will also be freed once back is removed.
    FixBot'a Sor
    Yorum Ekle
  7. Logitech Harmony 650 Battery Terminal Replacement: adım 7, 1 resimden 1.
    • Remove the rear cover.
    FixBot'a Sor
    Yorum Ekle
  8. Logitech Harmony 650 Battery Terminal Replacement, Battery Terminal: adım 8, 2 resimden 1. Logitech Harmony 650 Battery Terminal Replacement, Battery Terminal: adım 8, 2 resimden 2.
    • Using the small end of a spudger, pry out the terminal from the interior of the case.
    FixBot'a Sor
    Yorum Ekle
  9. Logitech Harmony 650 Battery Terminal Replacement: adım 9, 1 resimden 1.
    • Start from one side and work your way to the other side using the spudger.
    FixBot'a Sor
    Yorum Ekle
  10. Logitech Harmony 650 Battery Terminal Replacement: adım 10, 1 resimden 1.
    • Remove the terminal.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 38
Her zaman: 3,789
