Giriş
It is recommended to have the iFixit ProTech toolkit and have already taken the case apart.
Neye ihtiyacın var
Remove the battery cover by applying pressure to the indented area and pushing the cover toward the rear of the device.
Bu adımda kullanılan alet:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Remove the small plastic cover beneath the plastic LED housing by using a 3.0 flathead screwdriver and a spudger to pry it off. It is glued to the case. If you are having trouble removing it try applying some heat to loosen the glue.
Using the small end of a spudger, pry out the terminal from the interior of the case.
2 farklı kişi bu kılavuzu tamamladı.
