Ana içeriğe geç
Logitech Harmony 650 Button Replacement
Neye ihtiyacın var
  1. Logitech Harmony 650 Button Replacement, Case: adım 1, 2 resimden 1. Logitech Harmony 650 Button Replacement, Case: adım 1, 2 resimden 2.
    • Remove the battery cover by applying pressure to the indented area and pushing the cover toward the rear of the device.
    FixBot'a Sor
    Yorum Ekle
  2. Logitech Harmony 650 Button Replacement: adım 2, 1 resimden 1.
    • Remove the batteries using the silver pull tab.
    FixBot'a Sor
    Yorum Ekle
  3. Logitech Harmony 650 Button Replacement: adım 3, 1 resimden 1.
    • Using a J000 Philips head screwdriver remove the four 5mm screws around the rim of the battery chamber.
    FixBot'a Sor
    Yorum Ekle
  4. Logitech Harmony 650 Button Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Remove the small plastic cover beneath the plastic LED housing by using a 3.0 flathead screwdriver and a spudger to pry it off. It is glued to the case. If you are having trouble removing it try applying some heat to loosen the glue.
    FixBot'a Sor
    Yorum Ekle
  5. Logitech Harmony 650 Button Replacement: adım 5, 1 resimden 1.
    • Remove the two 5mm screws located underneath the cover using a J000 Philips screwdriver bit.
    FixBot'a Sor
    Yorum Ekle
  6. Logitech Harmony 650 Button Replacement: adım 6, 2 resimden 1. Logitech Harmony 650 Button Replacement: adım 6, 2 resimden 2.
    • Using a plastic opening tool, pry the case off starting from the top of the device (nearest the transmitter). There are 3 tabs along the side of the case and one at the back.
    • The top led protector plastic cover will also be freed once back is removed.
    FixBot'a Sor
    Yorum Ekle
  7. Logitech Harmony 650 Button Replacement: adım 7, 1 resimden 1.
    • Remove the rear cover.
    FixBot'a Sor
    Yorum Ekle
  8. Logitech Harmony 650 Button Replacement, Motherboard: adım 8, 2 resimden 1. Logitech Harmony 650 Button Replacement, Motherboard: adım 8, 2 resimden 2.
    • Using a J0 screwdriver remove the three 5mm screws holding the motherboard to the front face. Two are located just below the processor in the middle of the device and the third is located at the very bottom.
    FixBot'a Sor
    Yorum Ekle
  9. Logitech Harmony 650 Button Replacement: adım 9, 1 resimden 1.
    • Remove the motherboard by gently pulling it away from the case.
    FixBot'a Sor
    Yorum Ekle
  10. Logitech Harmony 650 Button Replacement, Button: adım 10, 1 resimden 1.
    • Using a spudger, gently pry the bottom retaining place from the front case.
    FixBot'a Sor
    Yorum Ekle
  11. Logitech Harmony 650 Button Replacement: adım 11, 2 resimden 1. Logitech Harmony 650 Button Replacement: adım 11, 2 resimden 2.
    • Peel away both the upper and lower sets of buttons using your fingers.
    FixBot'a Sor
    Yorum Ekle
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
8Kılavuz Yorumları
Good instructions. Where can I purchase new buttons???
Michael Freeman - Yanıt Paylaş
Hello, I would recommend looking on eBay for a broken remote with a good membrane, also check craigslist or potentially amazon. A quick search for one and I couldn't find a membrane.
Austin K - Yanıt Paylaş
I also am looking for a new button membrane, any ideas? gimmick73@hotmail.com
gimmick73 - Yanıt Paylaş
Good advice. I bought a used one from ebay to replace the one I bought brand new from bestbuy and promptly broke the screen by dropping it on the kitchen floor. I plan on replacing the worn buttons on the working used replacement with the buttons from my broken one, and perhaps the case as well. Will let you know how it works out.
Jeremiah Behrens - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 58
Her zaman: 14,726
