Giriş
It is recommended that you have the iFixit ProTech Tool Kit and have already taken out the Motherboard and removed the case.
Neye ihtiyacın var
Remove the battery cover by applying pressure to the indented area and pushing the cover toward the rear of the device.
Bu adımda kullanılan alet:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Remove the small plastic cover beneath the plastic LED housing by using a 3.0 flathead screwdriver and a spudger to pry it off. It is glued to the case. If you are having trouble removing it try applying some heat to loosen the glue.
Using a J0 screwdriver remove the three 5mm screws holding the motherboard to the front face. Two are located just below the processor in the middle of the device and the third is located at the very bottom.
Peel away both the upper and lower sets of buttons using your fingers.
I lost the power off button and help button they poped up and not sure where they went. Need to purchase them to replace them, can anyone help me out.
15 farklı kişi bu kılavuzu tamamladı.
8 Yorum
Good instructions. Where can I purchase new buttons???
Hello, I would recommend looking on eBay for a broken remote with a good membrane, also check craigslist or potentially amazon. A quick search for one and I couldn't find a membrane.
Austin K -
Good advice. I bought a used one from ebay to replace the one I bought brand new from bestbuy and promptly broke the screen by dropping it on the kitchen floor. I plan on replacing the worn buttons on the working used replacement with the buttons from my broken one, and perhaps the case as well. Will let you know how it works out.
Since I didn’t find a new membrane , I purchased conductive silver varnish and used it to restore conductive capabilities of worn buttons.
At least imediately after repare it is working just fine. I’ll report here how it lasts over time, if don’t forget.
This helped me get down to the unresponsive buttons. Like Wassilij I used conductive silver paint. Works well, like this
https://www.instructables.com/id/Fix-but...
Cheers
Instruction was working well. I had problem with only one button on the side of the display. I cleaned the contact surface of the button with the isopropyl alcohol. It had some small dust. Now the button is working much better, but it is still not perfect.
I think that the problem is with the black metal (magnet?) which has wear. Thanks for helping ! Great forum/guide.
