Ana içeriğe geç
Logitech Harmony 900 Button Pad Replacement
Neye ihtiyacın var
  1. Logitech Harmony 900 Button Pad Replacement, Battery: adım 1, 2 resimden 1. Logitech Harmony 900 Button Pad Replacement, Battery: adım 1, 2 resimden 2.
    • Press the oval shaped button on the lower back of the remote to release the battery cover.
    • While pressing the button, remove the cover.
    FixBot'a Sor
    Yorum Ekle
  2. Logitech Harmony 900 Button Pad Replacement: adım 2, 2 resimden 1. Logitech Harmony 900 Button Pad Replacement: adım 2, 2 resimden 2.
    • Push the battery in, pull it up, and slide it out.
    FixBot'a Sor
    Yorum Ekle
  3. Logitech Harmony 900 Button Pad Replacement, Motherboard: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using tweezers, peel off the sticker located under the battery cover to reveal two screws.
    FixBot'a Sor
    Yorum Ekle
  4. Logitech Harmony 900 Button Pad Replacement: adım 4, 2 resimden 1. Logitech Harmony 900 Button Pad Replacement: adım 4, 2 resimden 2.
    • Locate and unscrew the four 50mm screws using the Philips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. Logitech Harmony 900 Button Pad Replacement: adım 5, 1 resimden 1.
    • Use a credit card to pry the black, plastic, back cover off of the device.
    • You may need to get the process started with a metal prying tool before you start using the credit card.
    FixBot'a Sor
    Yorum Ekle
  6. Logitech Harmony 900 Button Pad Replacement: adım 6, 2 resimden 1. Logitech Harmony 900 Button Pad Replacement: adım 6, 2 resimden 2.
    • Locate the three 50mm screws on the back of the remote and remove them using the Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  7. Logitech Harmony 900 Button Pad Replacement: adım 7, 2 resimden 1. Logitech Harmony 900 Button Pad Replacement: adım 7, 2 resimden 2.
    • Pry the black, front face of the remote from the back silver part by inserting a credit card in between and sliding down.
    • Again, you may need to use a metal prying tool to get the separation started.
    FixBot'a Sor
    Yorum Ekle
  8. Logitech Harmony 900 Button Pad Replacement: adım 8, 2 resimden 1. Logitech Harmony 900 Button Pad Replacement: adım 8, 2 resimden 2.
    • When you look at the circuit board, you should see a ribbon attaching the board to the plastic casing.
    • A little lever is holding the ribbon in place. Lift the lever with your nail or a 2.5mm flat-head screwdriver. Move the ribbon away from the circuit board.
    FixBot'a Sor
    Yorum Ekle
  9. Logitech Harmony 900 Button Pad Replacement: adım 9, 2 resimden 1. Logitech Harmony 900 Button Pad Replacement: adım 9, 2 resimden 2.
    • Using the Philips #0 screwdriver, remove the three 50mm screws from the circuit board.
    FixBot'a Sor
    Yorum Ekle
  10. Logitech Harmony 900 Button Pad Replacement: adım 10, 1 resimden 1.
    • Using your hands, carefully separate the motherboard from the rest of the remote.
    FixBot'a Sor
    Yorum Ekle
  11. Logitech Harmony 900 Button Pad Replacement, Button Pad: adım 11, 2 resimden 1. Logitech Harmony 900 Button Pad Replacement, Button Pad: adım 11, 2 resimden 2.
    • Peel off the button pads from the device frame.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tyler Hanks
442 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S4-G5, Eyestone Fall 2017 USF Tampa, Team S4-G5, Eyestone Fall 2017 üyesi
USFT-EYESTONE-F17S4G5
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 26
Her zaman: 1,091
