Neye ihtiyacın var
Use the Opening Tool to open the port cover at the bottom of the remote control.
Bend the cover back to gain easy access to the screws.
Use the Phillips #0 screwdriver to remove the (3) three 6mm screws.
Push the opening tool into the gap along the side of the remote, then slide it across until you hear clicking sounds.
Use the Phillips #0 screwdriver to remove the (5) five 6mm screws.
Removing the gold charging connectors is a pain. The inner mounting points really didn’t want to let go. Rather than force it, since I ultimately didn’t need to pull the entire board for my fix (my son decided to stir a cocktail with our remote), I left them in place and was still able to slide the board enough to tilt it out.
Bir başkası bu kılavuzu tamamladı.
3 Yorum
How replace A Mitsubishi Remote Control
How replace A Mitsubishi Remote Control ?
Thanks
Air conditioning
