Ana içeriğe geç
Logitech Harmony Companion Button Pad Replacement
Neye ihtiyacın var
  1. Logitech Harmony Companion Button Pad Replacement, Remote Battery: adım 1, 1 resimden 1.
    • Hold the remote with the Logitech label toward you.
  2. Logitech Harmony Companion Button Pad Replacement: adım 2, 1 resimden 1.
    • Push the battery cover upward.
  3. Logitech Harmony Companion Button Pad Replacement: adım 3, 3 resimden 1. Logitech Harmony Companion Button Pad Replacement: adım 3, 3 resimden 2. Logitech Harmony Companion Button Pad Replacement: adım 3, 3 resimden 3.
    • Use your finger to lift the battery out of the compartment.
    • When the battery has lifted, push it up to remove it.
  4. Logitech Harmony Companion Button Pad Replacement, Remote Motherboard: adım 4, 2 resimden 1. Logitech Harmony Companion Button Pad Replacement, Remote Motherboard: adım 4, 2 resimden 2.
    • Remove the two 5.0 mm Phillips #0 screws.
  5. Logitech Harmony Companion Button Pad Replacement: adım 5, 2 resimden 1. Logitech Harmony Companion Button Pad Replacement: adım 5, 2 resimden 2.
    • Use the plastic opening tool to pry open the back cover of the remote.
    • It is recommended to have the point of the opening tool facing the back of the remote.
    • Insert the opening tool on each side of the bottom of the remote, and pull up until you hear the cover click open.
    • Pry the back cover off by sliding the plastic opening tool down each side.
  6. Logitech Harmony Companion Button Pad Replacement: adım 6, 2 resimden 1. Logitech Harmony Companion Button Pad Replacement: adım 6, 2 resimden 2.
    • Use the plastic opening tool to remove the motherboard.
  7. Logitech Harmony Companion Button Pad Replacement, Button Pad: adım 7, 3 resimden 1. Logitech Harmony Companion Button Pad Replacement, Button Pad: adım 7, 3 resimden 2. Logitech Harmony Companion Button Pad Replacement, Button Pad: adım 7, 3 resimden 3.
    • Lift the button pad up to remove it from the remote.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Cassidy Wardlow
716 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G3, Nance Fall 2017 USF Tampa, Team S1-G3, Nance Fall 2017 üyesi
USFT-NANCE-F17S1G3
3 Üyeler
4Kılavuz Yorumları
Ou pouvons nous commander «  Logitech Harmony Companion Button Pad Replacement »
Roger Tardif - Yanıt
Where can I purchase the button pad?
elijah - Yanıt
Also looking to find where to purchase. I called Logitech and they were clueless. My 4 year old was better equipped to respond.
Joshua Fuller - Yanıt
Thanks for posting these helpful steps. My harmony Companion was frustrating us because we had to press buttons really hard.
Cy Beaux - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 10
Son 30 gün: 30
Her zaman: 3,525
