Ana içeriğe geç
Logitech Harmony Companion Harmony Hub Motherboard Replacement
Neye ihtiyacın var
  1. Logitech Harmony Companion Harmony Hub Motherboard Replacement, Harmony Hub Motherboard: adım 1, 2 resimden 1. Logitech Harmony Companion Harmony Hub Motherboard Replacement, Harmony Hub Motherboard: adım 1, 2 resimden 2.
    • Remove the non-slip rubber pads on the bottom of the Harmony Hub.
  2. Logitech Harmony Companion Harmony Hub Motherboard Replacement: adım 2, 2 resimden 1. Logitech Harmony Companion Harmony Hub Motherboard Replacement: adım 2, 2 resimden 2.
    • Unscrew the four 6.0 mm Phillips #0 screws.
  3. Logitech Harmony Companion Harmony Hub Motherboard Replacement: adım 3, 1 resimden 1.
    • Insert the metal opening tool in the slit by the sensor.
    • Carefully separate the Harmony Hub cover from the base.
    • The metal opening tool could damage the device, so use with care.
  4. Logitech Harmony Companion Harmony Hub Motherboard Replacement: adım 4, 2 resimden 1. Logitech Harmony Companion Harmony Hub Motherboard Replacement: adım 4, 2 resimden 2.
    • Unscrew the 2.0 mm Phillips #0 at the bottom right of the motherboard.
    • Unscrew the 4.0 mm Phillips #0 at the top left of the motherboard.
  5. Logitech Harmony Companion Harmony Hub Motherboard Replacement: adım 5, 3 resimden 1. Logitech Harmony Companion Harmony Hub Motherboard Replacement: adım 5, 3 resimden 2. Logitech Harmony Companion Harmony Hub Motherboard Replacement: adım 5, 3 resimden 3.
    • Face the Harmony Hub base so the sensor is facing out.
    • Insert the plastic opening tool behind the motherboard on the gold section, which is to the right of the sensor.
    • Lift until you hear a click.
Sonuç
Cassidy Wardlow
662 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G3, Nance Fall 2017 USF Tampa, Team S1-G3, Nance Fall 2017 üyesi
USFT-NANCE-F17S1G3
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 495
