Ana içeriğe geç
Logitech Harmony Companion Remote Motherboard Replacement
Neye ihtiyacın var
  1. Logitech Harmony Companion Remote Motherboard Replacement, Remote Battery: adım 1, 1 resimden 1.
    • Hold the remote with the Logitech label toward you.
  2. Logitech Harmony Companion Remote Motherboard Replacement: adım 2, 1 resimden 1.
    • Push the battery cover upward.
  3. Logitech Harmony Companion Remote Motherboard Replacement: adım 3, 3 resimden 1. Logitech Harmony Companion Remote Motherboard Replacement: adım 3, 3 resimden 2. Logitech Harmony Companion Remote Motherboard Replacement: adım 3, 3 resimden 3.
    • Use your finger to lift the battery out of the compartment.
    • When the battery has lifted, push it up to remove it.
  4. Logitech Harmony Companion Remote Motherboard Replacement, Remote Motherboard: adım 4, 2 resimden 1. Logitech Harmony Companion Remote Motherboard Replacement, Remote Motherboard: adım 4, 2 resimden 2.
    • Remove the two 5.0 mm Phillips #0 screws.
  5. Logitech Harmony Companion Remote Motherboard Replacement: adım 5, 2 resimden 1. Logitech Harmony Companion Remote Motherboard Replacement: adım 5, 2 resimden 2.
    • Use the plastic opening tool to pry open the back cover of the remote.
    • It is recommended to have the point of the opening tool facing the back of the remote.
    • Insert the opening tool on each side of the bottom of the remote, and pull up until you hear the cover click open.
    • Pry the back cover off by sliding the plastic opening tool down each side.
  6. Logitech Harmony Companion Remote Motherboard Replacement: adım 6, 2 resimden 1. Logitech Harmony Companion Remote Motherboard Replacement: adım 6, 2 resimden 2.
    • Use the plastic opening tool to remove the motherboard.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Cassidy Wardlow
662 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G3, Nance Fall 2017 USF Tampa, Team S1-G3, Nance Fall 2017 üyesi
USFT-NANCE-F17S1G3
3 Üyeler
Bir Yorum
Any source on that motherboard? I've got two dead buttons and replacement remotes are expensive and hard to come by.
Karl Wooster - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 84
Her zaman: 5,687
