Ana içeriğe geç
Logitech Harmony Smart Control Remote Buttons Replacement
Neye ihtiyacın var
  1. Logitech Harmony Smart Control Remote Buttons Replacement, Remote Buttons: adım 1, 2 resimden 1. Logitech Harmony Smart Control Remote Buttons Replacement, Remote Buttons: adım 1, 2 resimden 2.
    • With both thumbs, slide the grooved cover off the end of the remote.
    • Remove the battery once cover is removed.
    FixBot'a Sor
  2. Logitech Harmony Smart Control Remote Buttons Replacement: adım 2, 2 resimden 1. Logitech Harmony Smart Control Remote Buttons Replacement: adım 2, 2 resimden 2.
    • With the PH00 bit, remove both of the 4mm Phillip screws on the remote.
    FixBot'a Sor
  3. Logitech Harmony Smart Control Remote Buttons Replacement: adım 3, 2 resimden 1. Logitech Harmony Smart Control Remote Buttons Replacement: adım 3, 2 resimden 2.
    • Using a metal spudger, pry the remote. Maneuver around to separate both sides.
    FixBot'a Sor
  4. Logitech Harmony Smart Control Remote Buttons Replacement: adım 4, 3 resimden 1. Logitech Harmony Smart Control Remote Buttons Replacement: adım 4, 3 resimden 2. Logitech Harmony Smart Control Remote Buttons Replacement: adım 4, 3 resimden 3.
    • Manualy separate the two pieces of plastic.
    • Using the metal piece from the housing, pry up the circuit board. Do not disconnect anything.
    • When the circuit board is pried, slide the circuit board out of the housing.
    FixBot'a Sor
  5. Logitech Harmony Smart Control Remote Buttons Replacement: adım 5, 1 resimden 1.
    • From the front of the remote, remove the buttons. Clean or replace the necessary buttons.
    FixBot'a Sor
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Josh Hendricks
464 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-2, Harley Fall 2015 IUPUI, Team 3-2, Harley Fall 2015 üyesi
IUPUI-HARLEY-F15S3G2
4 Üyeler
5 adet Kılavuz yazıldı
10Kılavuz Yorumları
Excellent guide. However, I can’t find a supplier for the button pad. Any suggestions?
fhaist - Yanıt Paylaş
Hi there,
My son dropped mine in water. I opened it and dried it off but it still doesn’t work.
I could give you my button pad if you want.
Benoit Lagarde - Yanıt Paylaş
Where do you purchase button replacements?
Steve Lutes - Yanıt Paylaş
Flavio Campos - Yanıt Paylaş
Excellent! I wasn’t sure if it was possible to crack it open or not. Thanks, I was able to clean it up.
John Wall - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 64
Her zaman: 6,411
