Ana içeriğe geç
Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement
Neye ihtiyacın var
  1. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement, Back Panel: adım 1, 2 resimden 1. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement, Back Panel: adım 1, 2 resimden 2.
    • Turn keyboard over to the backside.
    FixBot'a Sor
  2. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 2, 3 resimden 1. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 2, 3 resimden 2. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 2, 3 resimden 3.
    • Press and slide up on the upper battery latch, using both thumbs.
    FixBot'a Sor
  3. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 3, 1 resimden 1.
    • Remove the two AA batteries and set them aside.
    FixBot'a Sor
  4. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 4, 2 resimden 1. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 4, 2 resimden 2.
    • Unscrew all five 4.0 mm screws, using Phillips #1 screwdriver.
    FixBot'a Sor
  5. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 5, 2 resimden 1. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 5, 2 resimden 2.
    • Peel off the center sticker to reveal two hidden 4.0 mm screws.
    • Unscrew these two screws with a Phillips #1 screwdriver.
    FixBot'a Sor
  6. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 6, 3 resimden 1. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 6, 3 resimden 2. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 6, 3 resimden 3.
    • Lift both top left and top right rubber stickers halfway, using the sharp end of the plastic spudger.
    • Unscrew a total of two 4.0 mm screws, under the rubber stickers, using a Phillips #1 screwdriver.
    FixBot'a Sor
  7. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 7, 2 resimden 1. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 7, 2 resimden 2.
    • Unscrew the top center 4.0 mm screw, in the battery compartment, using the Phillips #1 screwdriver.
    • Now, you should have a total of ten 4.0 mm screws set aside.
    FixBot'a Sor
  8. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 8, 3 resimden 1. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 8, 3 resimden 2. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 8, 3 resimden 3.
    • Wedge the flat end of the spudger between the back panel and front panel.
    • Slide the flat end of the spudger from right to left to pry the two panels apart.
    FixBot'a Sor
  9. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 9, 3 resimden 1. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 9, 3 resimden 2. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 9, 3 resimden 3.
    • Separate the back panel from the front panel completely, using both hands.
    • A white ribbon flex cable will remain connected to both panels.
    • Pull the panels apart slowly and gently, or the white ribbon flex cable may be unsafely removed.
    FixBot'a Sor
  10. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement, Keyboard Printed Circuit Board (PCB): adım 10, 3 resimden 1. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement, Keyboard Printed Circuit Board (PCB): adım 10, 3 resimden 2. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement, Keyboard Printed Circuit Board (PCB): adım 10, 3 resimden 3.
    • Grip the lower end of the ribbon flex cable (white band) using your thumb and index finger.
    • Then slide the strip out toward yourself in a scooping motion.
    • Now, you should have two completely separated panel pieces.
    FixBot'a Sor
  11. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 11, 3 resimden 1. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 11, 3 resimden 2. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 11, 3 resimden 3.
    • Lift and remove the white rubber sheet that lays over the keyboard pet flexible PCB.
    FixBot'a Sor
  12. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 12, 3 resimden 1. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 12, 3 resimden 2. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 12, 3 resimden 3.
    • Unscrew the two 4.0 mm screws on either side of the green card using a Phillips #1 screwdriver.
    FixBot'a Sor
  13. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 13, 1 resimden 1.
    • Lift the green card up using the flat end of the plastic spudger.
    FixBot'a Sor
  14. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 14, 1 resimden 1.
    • Grip and lift the keyboard PCB up and out.
    • The battery wires will remain connected.
    FixBot'a Sor
  15. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 15, 1 resimden 1.
    • Grip and lift the battery wire bar out of the battery compartment, using your thumb and index finger.
    FixBot'a Sor
  16. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 16, 2 resimden 1. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 16, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Pinch your precision tweezers and wedge the battery clamp up.
    • Lift the entire keyboard PCB out of the panel.
    • The keyboard PCB will remain connected to the green card.
    FixBot'a Sor
  17. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 17, 3 resimden 1. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 17, 3 resimden 2. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 17, 3 resimden 3.
    • Slide your index finger into the slot under the right blue tab.
    • Pinch and pull the right blue tab away from the green card.
    FixBot'a Sor
  18. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 18, 3 resimden 1. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 18, 3 resimden 2. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: adım 18, 3 resimden 3.
    • Pinch and pull the left blue tab away from the green card.
    FixBot'a Sor
Sonuç
Bir başkası bu kılavuzu tamamladı.
Hayley Nichols
525 İtibar
4 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team S1-G2, Bruce Fall 2017 CSU Fullerton, Team S1-G2, Bruce Fall 2017 üyesi
CSUF-BRUCE-F17S1G2
3 Üyeler
10 adet Kılavuz yazıldı
2Kılavuz Yorumları
This is really very informative to read and helpful while replacement or cleaning theprinted circuit board . I really want my friend companies engineer to read this type of information and work on it in practical. i wanna tag that company here as well @XG-technologies (https://xg-pcb.com/). Moreover keep sharing these type of informative blogs. really liked it.
mark.tony40 - Yanıt Paylaş
dnde cmprar el recambi, cm se ve n funcina la 0
Manuel Sánchez Varilla - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 86
Her zaman: 4,733
