Ana içeriğe geç
Logitech Harmony Smart Keyboard On/Off Switch Replacement
Neye ihtiyacın var
  1. Logitech Harmony Smart Keyboard On/Off Switch Replacement, Back Panel: adım 1, 2 resimden 1. Logitech Harmony Smart Keyboard On/Off Switch Replacement, Back Panel: adım 1, 2 resimden 2.
    • Turn keyboard over to the backside.
  2. Logitech Harmony Smart Keyboard On/Off Switch Replacement: adım 2, 3 resimden 1. Logitech Harmony Smart Keyboard On/Off Switch Replacement: adım 2, 3 resimden 2. Logitech Harmony Smart Keyboard On/Off Switch Replacement: adım 2, 3 resimden 3.
    • Press and slide up on the upper battery latch, using both thumbs.
  3. Logitech Harmony Smart Keyboard On/Off Switch Replacement: adım 3, 1 resimden 1.
    • Remove the two AA batteries and set them aside.
  4. Logitech Harmony Smart Keyboard On/Off Switch Replacement: adım 4, 2 resimden 1. Logitech Harmony Smart Keyboard On/Off Switch Replacement: adım 4, 2 resimden 2.
    • Unscrew all five 4.0 mm screws, using Phillips #1 screwdriver.
  5. Logitech Harmony Smart Keyboard On/Off Switch Replacement: adım 5, 2 resimden 1. Logitech Harmony Smart Keyboard On/Off Switch Replacement: adım 5, 2 resimden 2.
    • Peel off the center sticker to reveal two hidden 4.0 mm screws.
    • Unscrew these two screws with a Phillips #1 screwdriver.
  6. Logitech Harmony Smart Keyboard On/Off Switch Replacement: adım 6, 3 resimden 1. Logitech Harmony Smart Keyboard On/Off Switch Replacement: adım 6, 3 resimden 2. Logitech Harmony Smart Keyboard On/Off Switch Replacement: adım 6, 3 resimden 3.
    • Lift both top left and top right rubber stickers halfway, using the sharp end of the plastic spudger.
    • Unscrew a total of two 4.0 mm screws, under the rubber stickers, using a Phillips #1 screwdriver.
  7. Logitech Harmony Smart Keyboard On/Off Switch Replacement: adım 7, 2 resimden 1. Logitech Harmony Smart Keyboard On/Off Switch Replacement: adım 7, 2 resimden 2.
    • Unscrew the top center 4.0 mm screw, in the battery compartment, using the Phillips #1 screwdriver.
    • Now, you should have a total of ten 4.0 mm screws set aside.
  8. Logitech Harmony Smart Keyboard On/Off Switch Replacement: adım 8, 3 resimden 1. Logitech Harmony Smart Keyboard On/Off Switch Replacement: adım 8, 3 resimden 2. Logitech Harmony Smart Keyboard On/Off Switch Replacement: adım 8, 3 resimden 3.
    • Wedge the flat end of the spudger between the back panel and front panel.
    • Slide the flat end of the spudger from right to left to pry the two panels apart.
  9. Logitech Harmony Smart Keyboard On/Off Switch Replacement: adım 9, 3 resimden 1. Logitech Harmony Smart Keyboard On/Off Switch Replacement: adım 9, 3 resimden 2. Logitech Harmony Smart Keyboard On/Off Switch Replacement: adım 9, 3 resimden 3.
    • Separate the back panel from the front panel completely, using both hands.
    • A white ribbon flex cable will remain connected to both panels.
    • Pull the panels apart slowly and gently, or the white ribbon flex cable may be unsafely removed.
  10. Logitech Harmony Smart Keyboard On/Off Switch Replacement, On/Off Switch: adım 10, 3 resimden 1. Logitech Harmony Smart Keyboard On/Off Switch Replacement, On/Off Switch: adım 10, 3 resimden 2. Logitech Harmony Smart Keyboard On/Off Switch Replacement, On/Off Switch: adım 10, 3 resimden 3.
    • Grip the lower end of the ribbon flex cable (white band) using your thumb and index finger.
    • Then slide the strip out toward yourself in a scooping motion.
    • Now, you should have two completely separated panel pieces.
  11. Logitech Harmony Smart Keyboard On/Off Switch Replacement: adım 11, 3 resimden 1. Logitech Harmony Smart Keyboard On/Off Switch Replacement: adım 11, 3 resimden 2. Logitech Harmony Smart Keyboard On/Off Switch Replacement: adım 11, 3 resimden 3.
    • Set aside the front panel and locate the green card atop the on/off switch on the back panel.
    • Unscrew the two 4.0 mm screws on either side of the green card using a Phillips #1 screwdriver.
  12. Logitech Harmony Smart Keyboard On/Off Switch Replacement: adım 12, 3 resimden 1. Logitech Harmony Smart Keyboard On/Off Switch Replacement: adım 12, 3 resimden 2. Logitech Harmony Smart Keyboard On/Off Switch Replacement: adım 12, 3 resimden 3.
    • Lift up and hold the left side of the green card with one index finger.
    • Grip and pull the on/off switch out with your other index finger and thumb.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Hayley Nichols
525 İtibar
4 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team S1-G2, Bruce Fall 2017 CSU Fullerton, Team S1-G2, Bruce Fall 2017 üyesi
CSUF-BRUCE-F17S1G2
3 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
please share switch rear side.. and where could we buy this switch.. ?
Praveen Krishnan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 28
Her zaman: 4,901
