Ana içeriğe geç
Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement
Neye ihtiyacın var
  1. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement, Back Panel: adım 1, 2 resimden 1. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement, Back Panel: adım 1, 2 resimden 2.
    • Turn keyboard over to the backside.
  2. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: adım 2, 3 resimden 1. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: adım 2, 3 resimden 2. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: adım 2, 3 resimden 3.
    • Press and slide up on the upper battery latch, using both thumbs.
  3. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: adım 3, 1 resimden 1.
    • Remove the two AA batteries and set them aside.
  4. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: adım 4, 2 resimden 1. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: adım 4, 2 resimden 2.
    • Unscrew all five 4.0 mm screws, using Phillips #1 screwdriver.
  5. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: adım 5, 2 resimden 1. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: adım 5, 2 resimden 2.
    • Peel off the center sticker to reveal two hidden 4.0 mm screws.
    • Unscrew these two screws with a Phillips #1 screwdriver.
  6. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: adım 6, 3 resimden 1. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: adım 6, 3 resimden 2. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: adım 6, 3 resimden 3.
    • Lift both top left and top right rubber stickers halfway, using the sharp end of the plastic spudger.
    • Unscrew a total of two 4.0 mm screws, under the rubber stickers, using a Phillips #1 screwdriver.
  7. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: adım 7, 2 resimden 1. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: adım 7, 2 resimden 2.
    • Unscrew the top center 4.0 mm screw, in the battery compartment, using the Phillips #1 screwdriver.
    • Now, you should have a total of ten 4.0 mm screws set aside.
  8. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: adım 8, 3 resimden 1. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: adım 8, 3 resimden 2. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: adım 8, 3 resimden 3.
    • Wedge the flat end of the spudger between the back panel and front panel.
    • Slide the flat end of the spudger from right to left to pry the two panels apart.
  9. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: adım 9, 3 resimden 1. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: adım 9, 3 resimden 2. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: adım 9, 3 resimden 3.
    • Separate the back panel from the front panel completely, using both hands.
    • A white ribbon flex cable will remain connected to both panels.
    • Pull the panels apart slowly and gently, or the white ribbon flex cable may be unsafely removed.
  10. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement, Touchpad Printed Circuit Board (PCB): adım 10, 3 resimden 1. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement, Touchpad Printed Circuit Board (PCB): adım 10, 3 resimden 2. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement, Touchpad Printed Circuit Board (PCB): adım 10, 3 resimden 3.
    • Lift up and pull off the track pad’s left and right clickers.
    • Use caution while lifting, lift slowly with slight pressure.
  11. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: adım 11, 3 resimden 1. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: adım 11, 3 resimden 2. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: adım 11, 3 resimden 3.
    • Grip the lower end of the ribbon flex cable (white band) using your thumb and index finger.
    • Then slide the strip out toward yourself in a scooping motion.
    • Now, you should have two completely separated panel pieces.
  12. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: adım 12, 1 resimden 1.
    • Flip the front panel over so the front side faces up, and rotate so the keys appear upside down.
    • Lift the upper-right corner of the sensor sticker using the sharp end of the spudger and your index finger.
  13. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: adım 13, 3 resimden 1. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: adım 13, 3 resimden 2. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: adım 13, 3 resimden 3.
    • Peel the sticker off by pinching the sticker corner using your index finger and thumb.
  14. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: adım 14, 2 resimden 1. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: adım 14, 2 resimden 2.
    • Rotate the front panel around so the keys appear right-side up.
    • Wedge the flat-head metal spudger under the PCB's bottom-right corner.
    • Wedge and slide the spudger along the right side to reach the upper-right corner.
  15. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: adım 15, 3 resimden 1. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: adım 15, 3 resimden 2. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: adım 15, 3 resimden 3.
    • Wedge the flat-head metal spudger under the PCB's bottom-left corner.
    • Wedge and slide the spudger along the bottom side to reach the bottom-right corner.
  16. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: adım 16, 3 resimden 1. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: adım 16, 3 resimden 2. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: adım 16, 3 resimden 3.
    • Slide and nudge the spudger upward underneath the PCB.
    • Wiggle and lift up the PCB with your thumb as you nudge the spudger up to release the PCB.
Sonuç
Edwin Aguilar
143 İtibar
1 Kılavuz yazıldı
Ekip
CSU Fullerton, Team S1-G2, Bruce Fall 2017 CSU Fullerton, Team S1-G2, Bruce Fall 2017 üyesi
CSUF-BRUCE-F17S1G2
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 18
Her zaman: 1,143
