Ana içeriğe geç
Logitech Harmony Touch Buttons Replacement
Neye ihtiyacın var
  1. Logitech Harmony Touch Buttons Replacement, Buttons: adım 1, 3 resimden 1. Logitech Harmony Touch Buttons Replacement, Buttons: adım 1, 3 resimden 2. Logitech Harmony Touch Buttons Replacement, Buttons: adım 1, 3 resimden 3.
    • Open the latch that accesses the charging port.
    • Remove the black sticker and the screw with the Phillips #0 Screwdriver.
    • Take the plastic opening tool and run it down the side of the remote to open the case.
    • While doing this step, three wires connect the two pieces, be sure not to rip them out.
    • Detach the white clamp to disconnect the case from the motherboard partially.
  2. Logitech Harmony Touch Buttons Replacement: adım 2, 3 resimden 1. Logitech Harmony Touch Buttons Replacement: adım 2, 3 resimden 2. Logitech Harmony Touch Buttons Replacement: adım 2, 3 resimden 3.
    • Peel back the thin yellow plastic film.
    • Detach the clip found underneath the film.
    • Remove the screws that connect the motherboard to the case with the Phillips #0 Screwdriver.
  3. Logitech Harmony Touch Buttons Replacement: adım 3, 3 resimden 1. Logitech Harmony Touch Buttons Replacement: adım 3, 3 resimden 2. Logitech Harmony Touch Buttons Replacement: adım 3, 3 resimden 3.
    • Next, carefully remove the motherboard from the top piece of the case.
    • The motherboard is connected to the bottom part of the case.
    • You should now be able to access all the buttons and remove them from the case.
  4. Logitech Harmony Touch Buttons Replacement: adım 4, 2 resimden 1. Logitech Harmony Touch Buttons Replacement: adım 4, 2 resimden 2.
    • Remove the buttons from the case.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Nicholas Townsend
285 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S4-G2, Eyestone Fall 2017 USF Tampa, Team S4-G2, Eyestone Fall 2017 üyesi
USFT-EYESTONE-F17S4G2
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 14
Her zaman: 1,716
