Ana içeriğe geç
Logitech Harmony Touch Motherboard Replacement
Neye ihtiyacın var
  1. Logitech Harmony Touch Motherboard Replacement, Motherboard: adım 1, 3 resimden 1. Logitech Harmony Touch Motherboard Replacement, Motherboard: adım 1, 3 resimden 2. Logitech Harmony Touch Motherboard Replacement, Motherboard: adım 1, 3 resimden 3.
    • Open the latch that accesses the charging port
    • Remove the black sticker and remove the screw with the indicated screwdriver
    • Take the plastic opening tool and run it down the side of the remote to pop the case open
    • While doing this step there are three wires that connect the two pieces, be sure not to rip them out
    • Detach the white clamp to partially disconnect the case from the motherboard
  2. Logitech Harmony Touch Motherboard Replacement: adım 2, 3 resimden 1. Logitech Harmony Touch Motherboard Replacement: adım 2, 3 resimden 2. Logitech Harmony Touch Motherboard Replacement: adım 2, 3 resimden 3.
    • Peel back thin yellow plastic film and detach the clip found underneath
    • Remove the screws that connect the motherboard to the case with the suggested screwdriver
    • Next, carefully remove the motherboard from the top piece of the case
    • The motherboard is connected to the bottom part of the case
    • You should now be able to access all of the buttons and remove them from the case
Sonuç
Lennox Saliva-Rojas
281 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S4-G2, Eyestone Fall 2017 USF Tampa, Team S4-G2, Eyestone Fall 2017 üyesi
USFT-EYESTONE-F17S4G2
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 691
