Ana içeriğe geç
Logitech Harmony Touch Power Adapter Replacement
Neye ihtiyacın var
  1. Logitech Harmony Touch Power Adapter Replacement, Power Adapter: adım 1, 1 resimden 1.
    • Open the latch that assesses the charging port.
    • Remove the black sticker and remove the screw with the indicated screwdriver.
  2. Logitech Harmony Touch Power Adapter Replacement: adım 2, 2 resimden 1. Logitech Harmony Touch Power Adapter Replacement: adım 2, 2 resimden 2.
    • Take the plastic opening tool and run it down the side of the remote to pop the case open.
    • While doing this step there are three wires that connect the two pieces, be sure not to rip them out when opening.
    • Detach the white clamp to partially disconnect the case from the motherboard.
  3. Logitech Harmony Touch Power Adapter Replacement: adım 3, 1 resimden 1.
    • Once your device is open, check to see if wires are intact.
    • If wires are not intact, solder your wires back in place to ensure contact with your charging port.
Sonuç
Jennifer Jimenez
219 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S4-G2, Eyestone Fall 2017 USF Tampa, Team S4-G2, Eyestone Fall 2017 üyesi
USFT-EYESTONE-F17S4G2
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 716
