Ana içeriğe geç
Logitech Harmony Ultimate Charging Station Motherboard Replacement
Neye ihtiyacın var
  1. Logitech Harmony Ultimate Charging Station Motherboard Replacement, Charging Station Motherboard: adım 1, 3 resimden 1. Logitech Harmony Ultimate Charging Station Motherboard Replacement, Charging Station Motherboard: adım 1, 3 resimden 2. Logitech Harmony Ultimate Charging Station Motherboard Replacement, Charging Station Motherboard: adım 1, 3 resimden 3.
    • Screws are hidden beneath rubber pads.
    • Peel off the rubber pads.
    • Remove four 6mm screws Phillips #0 screws from the bottom of the device.
  2. Logitech Harmony Ultimate Charging Station Motherboard Replacement: adım 2, 2 resimden 1. Logitech Harmony Ultimate Charging Station Motherboard Replacement: adım 2, 2 resimden 2.
    • Use the plastic opening tool to remove top shell from device.
  3. Logitech Harmony Ultimate Charging Station Motherboard Replacement: adım 3, 3 resimden 1. Logitech Harmony Ultimate Charging Station Motherboard Replacement: adım 3, 3 resimden 2. Logitech Harmony Ultimate Charging Station Motherboard Replacement: adım 3, 3 resimden 3.
    • Remove the two (4mm) screws using Phillips 1 screwdriver.
  4. Logitech Harmony Ultimate Charging Station Motherboard Replacement: adım 4, 3 resimden 1. Logitech Harmony Ultimate Charging Station Motherboard Replacement: adım 4, 3 resimden 2. Logitech Harmony Ultimate Charging Station Motherboard Replacement: adım 4, 3 resimden 3.
    • Use the Phillips #0 screwdriver to remove the last (4mm) screw. The motherboard can now be removed.
Sonuç
Lucas Reynolds
333 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 8-1, Eyestone Fall 2015 USF Tampa, Team 8-1, Eyestone Fall 2015 üyesi
USFT-EYESTONE-F15S8G1
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 23
Her zaman: 2,865
