Ana içeriğe geç
Logitech Harmony Ultimate Motherboard Replacement
Neye ihtiyacın var
  1. Logitech Harmony Ultimate Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the single 6 mm Phillips #0 screw located beneath the sticker near the USB charging port.
    FixBot'a Sor
    Yorum Ekle
  2. Logitech Harmony Ultimate Motherboard Replacement: adım 2, 2 resimden 1. Logitech Harmony Ultimate Motherboard Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool to release tabs that hold the front panel and back panel together. There are three tabs on each side of the device that need to separate for the device to open.
    • The use of a plastic opening tool is recommended to avoid damaging the remote. Use stronger tools as a last resort.
    • Be careful on the right side (looking at the back side) not to hit the screen ribbon cable. If that is hit and breaks, the touchscreen will not work properly. (example shown in the image)
    FixBot'a Sor
    Yorum Ekle
  3. Logitech Harmony Ultimate Motherboard Replacement: adım 3, 2 resimden 1. Logitech Harmony Ultimate Motherboard Replacement: adım 3, 2 resimden 2.
    • Disconnect the wires running from the back cover to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  4. Logitech Harmony Ultimate Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove the four 6mm Phillips #0 screws from the battery case.
    FixBot'a Sor
    Yorum Ekle
  5. Logitech Harmony Ultimate Motherboard Replacement: adım 5, 1 resimden 1.
    • The battery is still connected to the device via wiring. To free the battery completely, remove the dark plastic piece from the slot with the plastic opening tool. Slowly rotate the dark plastic piece and the battery clockwise until then can be removed from underneath the small circuit board with the USB port.
    • Removing the dark plastic piece from the motherboard takes some patience, as the remote is designed so that the battery will not dislocate under extreme conditions. The small circuit board with the USB port remains connected to the motherboard by six 10 mm pins.
    FixBot'a Sor
    Yorum Ekle
  6. Logitech Harmony Ultimate Motherboard Replacement: adım 6, 1 resimden 1.
    • Lift the battery and its case out of the remote.
    • The battery should still be connected to the case with adhesive.
    FixBot'a Sor
    Yorum Ekle
  7. Logitech Harmony Ultimate Motherboard Replacement: adım 7, 2 resimden 1. Logitech Harmony Ultimate Motherboard Replacement: adım 7, 2 resimden 2.
    • Use the plastic opening tool to separate the battery from the case.
    FixBot'a Sor
    Yorum Ekle
  8. Logitech Harmony Ultimate Motherboard Replacement, Motherboard: adım 8, 2 resimden 1. Logitech Harmony Ultimate Motherboard Replacement, Motherboard: adım 8, 2 resimden 2.
    • Remove the four 6mm Phillips #0 screws from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  9. Logitech Harmony Ultimate Motherboard Replacement: adım 9, 2 resimden 1. Logitech Harmony Ultimate Motherboard Replacement: adım 9, 2 resimden 2.
    • There is a flap that connects to the motherboard from the plastic casing. Use fingernails to safely release the flap by flipping the small black buckle upwards.
    • The flap and buckle are underneath the clear yellow piece of tape.
    • Be very careful as damaging this flap could permanently damage your controller.
    FixBot'a Sor
    Yorum Ekle
  10. Logitech Harmony Ultimate Motherboard Replacement: adım 10, 1 resimden 1.
    • The motherboard is now safe to remove by sliding and lifting it backwards out of place.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Aaron Diaz
728 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 8-1, Eyestone Fall 2015 USF Tampa, Team 8-1, Eyestone Fall 2015 üyesi
USFT-EYESTONE-F15S8G1
5 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 18
Her zaman: 2,923
