Ana içeriğe geç
Logitech K120 Keyboard Disassembly
Neye ihtiyacın var
Videoya Genel Bakış
    1. Logitech K120 Keyboard Disassembly, Removing Screws: adım 1, 2 resimden 1. Logitech K120 Keyboard Disassembly, Removing Screws: adım 1, 2 resimden 2.
      • Remove the Phillips #000 screw. Turn the screwdriver counter-clockwise.
      FixBot'a Sor
      Yorum Ekle
    2. Logitech K120 Keyboard Disassembly, Separating The Keyboard's Chassis: adım 2, 3 resimden 1. Logitech K120 Keyboard Disassembly, Separating The Keyboard's Chassis: adım 2, 3 resimden 2. Logitech K120 Keyboard Disassembly, Separating The Keyboard's Chassis: adım 2, 3 resimden 3.
      • Use the spudger to separate the top of keyboard from the bottom of the keyboard.
      FixBot'a Sor
      Yorum Ekle
    3. Logitech K120 Keyboard Disassembly, Removing The Top Of The Keyboard: adım 3, 1 resimden 1.
      • Remove the top of the keyboard and put it aside.
      FixBot'a Sor
      Yorum Ekle
    4. Logitech K120 Keyboard Disassembly, Removing The Bracket: adım 4, 3 resimden 1. Logitech K120 Keyboard Disassembly, Removing The Bracket: adım 4, 3 resimden 2. Logitech K120 Keyboard Disassembly, Removing The Bracket: adım 4, 3 resimden 3.
      • Unscrew the highlighted screws using a Phillips #000 Screwdriver. Turn the screwdriver counter-clockwise.
      FixBot'a Sor
      Yorum Ekle
    5. Logitech K120 Keyboard Disassembly, Removing The Circuit Board: adım 5, 3 resimden 1. Logitech K120 Keyboard Disassembly, Removing The Circuit Board: adım 5, 3 resimden 2. Logitech K120 Keyboard Disassembly, Removing The Circuit Board: adım 5, 3 resimden 3.
      • Use the spudger and carefully pry the connector out of its socket. (Highlighted in the pictures)
      FixBot'a Sor
      Yorum Ekle
    6. Logitech K120 Keyboard Disassembly, Removing The Cable: adım 6, 2 resimden 1. Logitech K120 Keyboard Disassembly, Removing The Cable: adım 6, 2 resimden 2.
      • Carefully nudge the connector out of the hole in which the cable enters the keyboard's chassis.
      FixBot'a Sor
      Yorum Ekle
    7. Logitech K120 Keyboard Disassembly, Removing The Membrane: adım 7, 2 resimden 1. Logitech K120 Keyboard Disassembly, Removing The Membrane: adım 7, 2 resimden 2.
      • Peel the membrane off carefully so that the membrane doesn't rip.
      FixBot'a Sor
      Yorum Ekle
    8. Logitech K120 Keyboard Disassembly, Remove The 2nd Membrane: adım 8, 3 resimden 1. Logitech K120 Keyboard Disassembly, Remove The 2nd Membrane: adım 8, 3 resimden 2. Logitech K120 Keyboard Disassembly, Remove The 2nd Membrane: adım 8, 3 resimden 3.
      • Stick the sharp end of the spudger into the corner of the second membrane and bring the spudger partly underneath the membrane.
      • Lift the membrane off of the first standoff.
      • Peel the rest of the membrane off carefully so the membrane doesn't rip.
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
4 farklı kişi bu kılavuzu tamamladı.
Camuise
1.675 İtibar
7 adet Kılavuz yazıldı
4Kılavuz Yorumları
I followed your guide for disassembly and did the opposite for reassembly, now all three leds turn on when plugged in but none of the keys respond. Any idea what I should do?
Jacob Sileski - Yanıt Paylaş
Make sure that the rubber membrane is making contact with the pads on the plastic sheets. If they are, make sure the connector is fully plugged in. If it is, make sure the keyboard is plugged into the right USB port.
Camuise - Yanıt Paylaş
Haven't answered my real question does one repair or replace circuit membrane when liquid has shorted on line? Or throw out and buy a new keyboard?
KimKostyna - Yanıt Paylaş
Your best bet is to try and clean up the membrane using isopropyl alcohol. There doesn't seem to be anywhere to buy a new circuit membrane, so if that doesn't work you'll most likely have to buy a new keyboard.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 33
Son 30 gün: 165
Her zaman: 13,855
