Ana içeriğe geç
Logitech K120 Keyboard USB Cable Replacement
Neye ihtiyacın var
  1. Logitech K120 Keyboard USB Cable Replacement, Removing Screws: adım 1, 2 resimden 1. Logitech K120 Keyboard USB Cable Replacement, Removing Screws: adım 1, 2 resimden 2.
    • Remove the Phillips #000 screw. Turn the screwdriver counter-clockwise.
  2. Logitech K120 Keyboard USB Cable Replacement, Separating The Keyboard's Chassis: adım 2, 3 resimden 1. Logitech K120 Keyboard USB Cable Replacement, Separating The Keyboard's Chassis: adım 2, 3 resimden 2. Logitech K120 Keyboard USB Cable Replacement, Separating The Keyboard's Chassis: adım 2, 3 resimden 3.
    • Use the spudger to separate the top of keyboard from the bottom of the keyboard.
  3. Logitech K120 Keyboard USB Cable Replacement, Removing The Top Of The Keyboard: adım 3, 1 resimden 1.
    • Remove the top of the keyboard and put it aside.
  4. Logitech K120 Keyboard USB Cable Replacement, Removing The Bracket: adım 4, 3 resimden 1. Logitech K120 Keyboard USB Cable Replacement, Removing The Bracket: adım 4, 3 resimden 2. Logitech K120 Keyboard USB Cable Replacement, Removing The Bracket: adım 4, 3 resimden 3.
    • Unscrew the highlighted screws using a Phillips #000 Screwdriver. Turn the screwdriver counter-clockwise.
  5. Logitech K120 Keyboard USB Cable Replacement, Removing The Circuit Board: adım 5, 3 resimden 1. Logitech K120 Keyboard USB Cable Replacement, Removing The Circuit Board: adım 5, 3 resimden 2. Logitech K120 Keyboard USB Cable Replacement, Removing The Circuit Board: adım 5, 3 resimden 3.
    • Use the spudger and carefully pry the connector out of its socket. (Highlighted in the pictures)
  6. Logitech K120 Keyboard USB Cable Replacement, Removing The Cable: adım 6, 2 resimden 1. Logitech K120 Keyboard USB Cable Replacement, Removing The Cable: adım 6, 2 resimden 2.
    • Carefully nudge the connector out of the hole in which the cable enters the keyboard's chassis.
  7. Logitech K120 Keyboard USB Cable Replacement, Removing The Membrane: adım 7, 2 resimden 1. Logitech K120 Keyboard USB Cable Replacement, Removing The Membrane: adım 7, 2 resimden 2.
    • Peel the membrane off carefully so that the membrane doesn't rip.
  8. Logitech K120 Keyboard USB Cable Replacement, Remove The 2nd Membrane: adım 8, 3 resimden 1. Logitech K120 Keyboard USB Cable Replacement, Remove The 2nd Membrane: adım 8, 3 resimden 2. Logitech K120 Keyboard USB Cable Replacement, Remove The 2nd Membrane: adım 8, 3 resimden 3.
    • Stick the sharp end of the spudger into the corner of the second membrane and bring the spudger partly underneath the membrane.
    • Lift the membrane off of the first standoff.
    • Peel the rest of the membrane off carefully so the membrane doesn't rip.
  9. Logitech K120 Keyboard USB Cable Replacement, Install The New Cable: adım 9, 3 resimden 1. Logitech K120 Keyboard USB Cable Replacement, Install The New Cable: adım 9, 3 resimden 2. Logitech K120 Keyboard USB Cable Replacement, Install The New Cable: adım 9, 3 resimden 3.
    • Slide the new cable into the hole.
  10. Logitech K120 Keyboard USB Cable Replacement, Connect The New Cable: adım 10, 3 resimden 1. Logitech K120 Keyboard USB Cable Replacement, Connect The New Cable: adım 10, 3 resimden 2. Logitech K120 Keyboard USB Cable Replacement, Connect The New Cable: adım 10, 3 resimden 3.
    • Connect The Cable To The Circuit Board.
Sonuç
To reassemble your device, follow the instructions on how to reassemble your device in the prerequisite guide.
Marcus Jones
1.145 İtibar
6 adet Kılavuz yazıldı
Bir Yorum
Hi there,
Nice guide! Where do I get hold of a replacement USB wire / what’s the specific name of it?
Thanks,
Robin
Robin Lane - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 67
Her zaman: 2,500
