Ana içeriğe geç
Logitech K480 Back Cover Replacement
Neye ihtiyacın var
    1. Logitech K480 Back Cover Replacement, Back Cover: adım 1, 1 resimden 1.
      • Flip the keyboard over.
      FixBot'a Sor
      Yorum Ekle
    2. Logitech K480 Back Cover Replacement: adım 2, 3 resimden 1. Logitech K480 Back Cover Replacement: adım 2, 3 resimden 2. Logitech K480 Back Cover Replacement: adım 2, 3 resimden 3.
      • Remove the four rubber feet with a spudger.
      FixBot'a Sor
      Yorum Ekle
    3. Logitech K480 Back Cover Replacement: adım 3, 3 resimden 1. Logitech K480 Back Cover Replacement: adım 3, 3 resimden 2. Logitech K480 Back Cover Replacement: adım 3, 3 resimden 3.
      • Slide open battery panel.
      • Remove the batteries.
      FixBot'a Sor
      Yorum Ekle
    4. Logitech K480 Back Cover Replacement: adım 4, 2 resimden 1. Logitech K480 Back Cover Replacement: adım 4, 2 resimden 2.
      • Remove the three 4 mm screws under the rubber feet using a Phillips #0 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    5. Logitech K480 Back Cover Replacement: adım 5, 2 resimden 1. Logitech K480 Back Cover Replacement: adım 5, 2 resimden 2.
      • Remove the two 4 mm screws from beneath the battery cover using a Phillips #0 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    6. Logitech K480 Back Cover Replacement: adım 6, 3 resimden 1. Logitech K480 Back Cover Replacement: adım 6, 3 resimden 2. Logitech K480 Back Cover Replacement: adım 6, 3 resimden 3.
      • Starting by the dial, slide the spudger between the front and back panels until it lifts and snaps.
      • Slide a blue pick in to keep the pieces apart while you work on other areas.
      • Continue prying along the edges until you have enough opened that you can pull both pieces apart gently with your hands.
      • The loud snaps are the clips that hold the pieces together. They're not breaking and you do not need to be alarmed.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Madison
778 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 25
Son 30 gün: 82
Her zaman: 1,013
