Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Logitech K700 Keyboard cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    : adım 1, 1 resimden 1.
    • Turn the keyboard over and slide the battery cover in the direction of the arrows slightly, and then lift the cover away.
  2. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    : adım 2, 1 resimden 1.
    • Remove the batteries and the two screws shown.
  3. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    : adım 3, 1 resimden 1.
    • Use a thumbnail or a pick to separate the clips around the periphery between the black and white plastic parts.
    • There are 4 clips on the top, 2 on either side, and 5 along the bottom. If you do the sides and top first, the bottom should slide out.
    • Don't separate the top and bottom immediately, since there are a couple of cables (near the touch pad) that connect between the two.
  4. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    : adım 4, 1 resimden 1.
    • The smaller of the two cables is for the touchpad. Lift the catch on its connector in order to slide it out.
    • The larger cable is for the key matrix. Just pull it out from the connector (friction fit).
    • This is as far as you can easily disassemble the keyboard. To go further requires removing 12 screws and 35 plastic rivets. This is not recommended.
    • To clean the keyboard of liquid, I suggest holding it over a sink with the touchpad side up, then spraying plenty of isopropyl alcohol from the back, avoiding the touch-pad area (you may wish to mask it off). Let dry completely before reassembling.
    • If keys still do not function after cleaning, then it is possible that traces on the key matrix have become corroded. This is not repairable, since the key matrix is a sealed unit. It consists of 3 layers of plastic that are sealed together. Unfortunately, it is not 100% sealed to prevent entry of liquids.
  5. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    : adım 5, 1 resimden 1.
    • Should you go further and remove the 12 screws and 35 plastic rivets, you can see this.
  6. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    : adım 6, 1 resimden 1.
    • The keys can be popped out easily enough by pushing from the back side. This exposes the key matrix.
  7. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    : adım 7, 1 resimden 1.
    • Here is the key matrix in all its glory.
cityzen
4.081 İtibar
2 adet Kılavuz yazıldı
3 Yorum
Very helpful! I combined this and cleaning the battery compartments with a white vinegar drenched Q-Tip to clean out some old battery corrosion, and now it turns on!
mpeterfin - Yanıt
any way you could send me a pic of the backside of the battery cover? i’d like to try to recreate it with a 3d printer
Cody Nelson - Yanıt
codycnelson@gmail.com :)
Cody Nelson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 30
Son 30 gün: 68
Her zaman: 15,830
