Ana içeriğe geç
Logitech M100 USB Cable Replacement
Neye ihtiyacın var
  1. Logitech M100 USB Cable Replacement, USB Cable: adım 1, 2 resimden 1. Logitech M100 USB Cable Replacement, USB Cable: adım 1, 2 resimden 2.
    • Not all variants of this mouse require the mouse feet to be taken off for disassembly, but their removal is detailed anyway.
    • Carefully remove the feet of the mouse with an opening pick.
    • Keep track of the mouse feet, as you'll be reapplying them at the end of the guide.
  2. Logitech M100 USB Cable Replacement: adım 2, 2 resimden 1. Logitech M100 USB Cable Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the 10mm screws on the bottom of the mouse.
    • Once all screws are removed, use the plastic opening tool to gently pry the mouse apart. This shouldn't take much force.
  3. Logitech M100 USB Cable Replacement: adım 3, 2 resimden 1. Logitech M100 USB Cable Replacement: adım 3, 2 resimden 2.
    • Once the mouse is opened, locate the USB cable's 5-pin connector, which is plugged directly into the mouse's mainboard.
    • Take note of the position and route that the USB cable takes before removal. The replacement cable must follow the same route when inserted.
    • Using a plastic opening tool, gently remove the 5-pin connector from the mainboard.
    Interessante mas muito básico.
    Interessante seria se explicasse o significado das cores
    Cabo Verde(Green) -
    Cabo Branco(White) -
    Cabo Vermelho(Red) - (Julgo ser 5v+)
    Cabo Preto Fino(thin Back) - (Julgo ser terra (GND)
    Cabo Preto Grosso(thick Back) - (Julgo ser massa Chassi)
    É bem mais interessante aprender e saber do que ir comprar já feito.
    Mais a mais, temos por vezes a necessidade de o rato tenha cabo curto e não longo (encurtar o cabo)
    CarlosAulasEVT@gmail
    Carlos Sousa - Yanıt
  4. Logitech M100 USB Cable Replacement: adım 4, 2 resimden 1. Logitech M100 USB Cable Replacement: adım 4, 2 resimden 2.
    • Take the replacement USB cable and connect it to the mainboard.
  5. Logitech M100 USB Cable Replacement: adım 5, 2 resimden 1. Logitech M100 USB Cable Replacement: adım 5, 2 resimden 2.
    • Ensure that the 5-pin connector is fully seated into its slot on the mainboard. You may want to use a spudger to apply pressure onto it.
    • Using a plastic opening tool, route the cable through the case in the same way that was noted in Step 3.
  6. Logitech M100 USB Cable Replacement: adım 6, 1 resimden 1.
    • After re-assembling the mouse, don't forget to reattach the mouse feet onto their correct locations on the bottom of the mouse.
Sonuç
To reassemble, follow the steps in reverse order.
4 farklı kişi bu kılavuzu tamamladı.
Jake Janicke
161 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
Removing the mouse feet is completely unnecessary, as there are no screws underneath the feet.
Andy Joonseo Bae - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 42
Her zaman: 5,701
