Ana içeriğe geç
Logitech M185 Wireless Mouse Disassembly
Neye ihtiyacın var
  1. Logitech M185 Wireless Mouse Disassembly, Remove the Battery Cover and Battery: adım 1, 2 resimden 1. Logitech M185 Wireless Mouse Disassembly, Remove the Battery Cover and Battery: adım 1, 2 resimden 2.
    • Remove battery cover by sliding it off.
    FixBot'a Sor
    Yorum Ekle
  2. Logitech M185 Wireless Mouse Disassembly, Unscrew: adım 2, 2 resimden 1. Logitech M185 Wireless Mouse Disassembly, Unscrew: adım 2, 2 resimden 2.
    • Unscrew the Phillips #1 screw in the battery compartment after removing the battery.
    • Some mice have a smaller screw, directly down and to the side of the on/off slider. The rest of the disassembly is the same.
    FixBot'a Sor
    Yorum Ekle
  3. Logitech M185 Wireless Mouse Disassembly, Remove the top cover: adım 3, 1 resimden 1.
    • There is no need to remove its rubber feet since it is held together by only one screw.
    • Wiggle the grey part of the top to remove it by pulling it towards you(away from the scroll wheel).
    • Do not pull the grey cover towards the top and do not pull the part near the keys.
    • Reasoning by Jacob Hickey "because in the internal top part of the mouse where the buttons/scroll wheel is, there’s hinges-like “tooth” that’ll snap if you do pull on it. It’s like opening a jewelry box that has a hinge on one end of the box… if that makes sense…"
    • The image is what your mouse should look like in the end.
    FixBot'a Sor
    Yorum Ekle
  4. Logitech M185 Wireless Mouse Disassembly, Remove Circuit Board: adım 4, 3 resimden 1. Logitech M185 Wireless Mouse Disassembly, Remove Circuit Board: adım 4, 3 resimden 2. Logitech M185 Wireless Mouse Disassembly, Remove Circuit Board: adım 4, 3 resimden 3.
    • Push back small black clips to release the circuit board.
    • Slide up the metal battery connectors to free them from the casing. (Note that these are soldered to the circuit board.)
    • Fully remove the circuit board with the battery connectors and image sensor still attached.
    FixBot'a Sor
    Yorum Ekle
  5. Logitech M185 Wireless Mouse Disassembly, Separate top casing layers: adım 5, 3 resimden 1. Logitech M185 Wireless Mouse Disassembly, Separate top casing layers: adım 5, 3 resimden 2. Logitech M185 Wireless Mouse Disassembly, Separate top casing layers: adım 5, 3 resimden 3.
    • Working from back to front (left to right in the first image) unclip the first two pairs of black plastic clips.
    • Slide the black upper casing forwards over the mouse wheel whilst applying pressure the two front clips to release them.
    • Separate the two casing layers fully.
    FixBot'a Sor
    Yorum Ekle
Sonuç
42 farklı kişi bu kılavuzu tamamladı.
Karmanyaah Malhotra
1.164 İtibar
1 Kılavuz yazıldı
12Kılavuz Yorumları
Thank you Karmanyaah Malhotra for takin’ the time to do this for everybody like me :-)
Jacob Hickey - Yanıt Paylaş
TElll me now or else
Brayden Karanian - Yanıt Paylaş
I will be sad
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 15
Son 7 gün: 95
Son 30 gün: 494
Her zaman: 43,309
