Ana içeriğe geç
Logitech M215 Battery Replacement
Neye ihtiyacın var
  1. Logitech M215 Battery Replacement, Remove the battery cover: adım 1, 3 resimden 1. Logitech M215 Battery Replacement, Remove the battery cover: adım 1, 3 resimden 2. Logitech M215 Battery Replacement, Remove the battery cover: adım 1, 3 resimden 3.
    • The battery compartment cover is located on the top of the mouse. The seam running horizontally across the mouse is the top of the cover.
    • There is a button to pop off the cover. It is located on the bottom of the mouse. you may need to press hard on this button to pop the cover.
    • If the button does not work, you will need to pry off the cover. You can use your fingernails or a prying tool in order to do this, as seen in the third image.
    The battery lid lifts up from the back. It does not slide back.
    Bob Peters - Yanıt
    U need to keep clean…& battery compartment needs gently pried off. Make sure to put back lid cover, pushing down on black prong..OR will not make contact.
    cconradmoore - Yanıt
    Thanks to u, i succeeded
    aresa0519 - Yanıt
  2. Logitech M215 Battery Replacement, Remove old battery: adım 2, 1 resimden 1.
    • Remember to insert the new battery in the same orientation as the old one. The positive (plus) end should be facing away from the buttons.
    After replacing battery light goes on then off. I tried it twice. Do I need a new part.
    Elsie Sarkisian - Yanıt
    After replacing battery the remote green light goes on then off. I tried it twice
    What do u mean reverse order?
    The laser light did not go on
    Thank you this worked nicely
    - Reworld - - Yanıt
    Thanks for this!
    Tiara Dubb - Yanıt
Sonuç
28 farklı kişi bu kılavuzu tamamladı.
Hannah Pate
1.734 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Watkins Winter 2015 USF Tampa, Team 1-1, Watkins Winter 2015 üyesi
USFT-WATKINS-W15S1G1
4 Üyeler
28 adet Kılavuz yazıldı
10 Yorum
I disassembled this exactly as stated and now I can't get the cover back on?
Rei Peterson - Yanıt
I am a electronic technologist and this is a poor design for a mouse. No wonder the later version is different.
Joseph Wonderless - Yanıt
Thanks for the information. It worked perfectly for me. Easy removal. Images and instructions were very helpful.
Tracy Moore - Yanıt
The green battery light went on, although the lazar light did not. What should I do?
Susan Petho - Yanıt
well this is a bit horrible, because i don’t have an extra AA battery.. and i have a M325, but the battery life is dead..
Diana Lee - Yanıt
I struggled to get the lid off until I realized that the lid lifts up from the back, it does not slide back. Once I found that out, it’s quite easy to open and close.
Bob Peters - Yanıt
hey! the battery is like stuck, how do i get it out? anyone?
angie - Yanıt
Sachin Tripathi - Yanıt
great help ,easy when you know how
Tim OBrien - Yanıt
Your post is beneficial. I can follow it can change the battery of the M215. If you have any posts, I will read all of them because I'm spacebar clicker
Hanry Han - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 21
Son 7 gün: 117
Son 30 gün: 599
Her zaman: 113,642
