Ana içeriğe geç
Logitech M215 Cover Release Button Replacement
Neye ihtiyacın var
  1. Logitech M215 Cover Release Button Replacement, Remove the battery cover: adım 1, 3 resimden 1. Logitech M215 Cover Release Button Replacement, Remove the battery cover: adım 1, 3 resimden 2. Logitech M215 Cover Release Button Replacement, Remove the battery cover: adım 1, 3 resimden 3.
    • The battery compartment cover is located on the top of the mouse. The seam running horizontally across the mouse is the top of the cover.
    • There is a button to pop off the cover. It is located on the bottom of the mouse. you may need to press hard on this button to pop the cover.
    • If the button does not work, you will need to pry off the cover. You can use your fingernails or a prying tool in order to do this, as seen in the third image.
  2. Logitech M215 Cover Release Button Replacement, Remove old battery: adım 2, 1 resimden 1.
    • Remember to insert the new battery in the same orientation as the old one. The positive (plus) end should be facing away from the buttons.
  3. Logitech M215 Cover Release Button Replacement, Top Cover: adım 3, 2 resimden 1. Logitech M215 Cover Release Button Replacement, Top Cover: adım 3, 2 resimden 2.
    • The pads on the underside of the mouse hide the screws. Remove these first. You may need to use your fingernails or a prying tool.
    • There will be two 0.5mm phillips head screws. Both will be underneath the bottom two pads.
  4. Logitech M215 Cover Release Button Replacement: adım 4, 1 resimden 1.
    • Pry the top cover off. You may need to use a pry tool to help.
  5. Logitech M215 Cover Release Button Replacement, Motherboard: adım 5, 2 resimden 1. Logitech M215 Cover Release Button Replacement, Motherboard: adım 5, 2 resimden 2.
    • Unscrew the 0.25mm phillips head screw to release the circuit board.
  6. Logitech M215 Cover Release Button Replacement, Cover Release Button: adım 6, 3 resimden 1. Logitech M215 Cover Release Button Replacement, Cover Release Button: adım 6, 3 resimden 2. Logitech M215 Cover Release Button Replacement, Cover Release Button: adım 6, 3 resimden 3.
    • Unscrew the 0.25mm phillips head screw holding the button in place. The cover release button can then be removed.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Hannah Pate
1.742 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Watkins Winter 2015 USF Tampa, Team 1-1, Watkins Winter 2015 üyesi
USFT-WATKINS-W15S1G1
4 Üyeler
28 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 27
Her zaman: 3,539
