Ana içeriğe geç
Logitech M215 Scroll Wheel Replacement
Neye ihtiyacın var
    1. Logitech M215 Scroll Wheel Replacement, Remove the battery cover: adım 1, 3 resimden 1. Logitech M215 Scroll Wheel Replacement, Remove the battery cover: adım 1, 3 resimden 2. Logitech M215 Scroll Wheel Replacement, Remove the battery cover: adım 1, 3 resimden 3.
      • The battery compartment cover is located on the top of the mouse. The seam running horizontally across the mouse is the top of the cover.
      • There is a button to pop off the cover. It is located on the bottom of the mouse. you may need to press hard on this button to pop the cover.
      • If the button does not work, you will need to pry off the cover. You can use your fingernails or a prying tool in order to do this, as seen in the third image.
      FixBot'a Sor
      Yorum Ekle
    2. Logitech M215 Scroll Wheel Replacement, Remove old battery: adım 2, 1 resimden 1.
      • Remember to insert the new battery in the same orientation as the old one. The positive (plus) end should be facing away from the buttons.
      FixBot'a Sor
      Yorum Ekle
    1. Logitech M215 Scroll Wheel Replacement, Button Plate: adım 3, 2 resimden 1. Logitech M215 Scroll Wheel Replacement, Button Plate: adım 3, 2 resimden 2.
      • Use your fingernail to carefully remove the two skid stickers from the fat (non-button) end of the bottom of the mouse to reveal two Philips head screws. Remove these, then unclip the bottom cover. Don't get the sticky dusty. Now remove buttons; they're both attached by one 0.5mm Phillips head screw. It is located in the center of the top cover.
      FixBot'a Sor
      Yorum Ekle
    2. Logitech M215 Scroll Wheel Replacement, Pry off buttons: adım 4, 2 resimden 1. Logitech M215 Scroll Wheel Replacement, Pry off buttons: adım 4, 2 resimden 2.
      • The button are now only attached by a small overhang near the front. You will need to use the pry tool to push the button plate off of this overhang as shown.
      • The button plate should be able to be completely removed at this point.
      FixBot'a Sor
      Yorum Ekle
    1. Logitech M215 Scroll Wheel Replacement, Scroll Wheel: adım 5, 1 resimden 1.
      • Use the prying tool to remove the scroll wheel. The wheel is held in place by two pegs which stick into the plastic holder.
      FixBot'a Sor
      Yorum Ekle
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Hannah Pate
1.742 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Watkins Winter 2015 USF Tampa, Team 1-1, Watkins Winter 2015 üyesi
USFT-WATKINS-W15S1G1
4 Üyeler
28 adet Kılavuz yazıldı
6Kılavuz Yorumları
glad I was able to find this info on disassembly. Gave it a good cleaning and works better than it did before. Had the Phillips screwdriver. and used another small screwdriver and a small pocket knife to pry with. Be gentle - doesn’t look like it would take much force to break those plastic bits.
carmenanddave - Yanıt Paylaş
Thanks! Mouse wheel windows were blocked by lint.
levensonjb - Yanıt Paylaş
Very useful. Cleaned coffee out of mouse wheel spokes/windows and off of chipboard. Works better than before. Thanks!
OGrady Watson - Yanıt Paylaş
Probably the BROWN stuff wasn’t coffee, I too cleaned the spokes/windows. the brown stuff is oil from out hands which lands on scroll wheel, then by heat gets transferred to the spokes. touch a finger on the mirror, the fingerprint on the mirror is because of OIL on hands. it is the same oil in that mouse wheel spokes.
tejaswin_jain - Yanıt Paylaş
There is a spring here connected to the wheel. Seems to be the thing to give tactical feedback when scrolling. It fell out when I took out the wheel not 100% how to put it back
Dan Molnar - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 15
Son 30 gün: 82
Her zaman: 14,609
