Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Logitech M Series Mouse cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Logitech M235 Teardown, Logitech M235 Teardown: adım 1, 1 resimden 1.
    • Remove the battery and battery cover
  2. Logitech M235 Teardown: adım 2, 2 resimden 1. Logitech M235 Teardown: adım 2, 2 resimden 2.
    • Remove the the two screws holding the cover.
    • I had two of these mouses and one of them had a screw hidden under the CE sticker so make sure you check it out before opening the mouse apart
  3. Logitech M235 Teardown: adım 3, 1 resimden 1.
    • Use a prying tool to split the mouse case apart.
  4. Logitech M235 Teardown: adım 4, 1 resimden 1.
    • The case should be easy to open and not require much force.
  5. Logitech M235 Teardown: adım 5, 1 resimden 1.
    • The PCB is only held by a few clips and can be easily removed.
  6. Logitech M235 Teardown: adım 6, 1 resimden 1.
    • The top mouse cover can be removed by undoing three white clips holding it on the grey plastic part.
  7. Logitech M235 Teardown: adım 7, 1 resimden 1.
    • Done!
Daniel
225 İtibar
1 Kılavuz yazıldı
Ekip
4Bits Repairs 4Bits Repairs üyesi
Business
1 Üye
2 adet Kılavuz yazıldı
8Kılavuz Yorumları
Great work. Hope to see some more of your work
Mustafa karu - Yanıt
thank you..this helped me a looot
Sharnav Kundu - Yanıt
My M325 has NO SCREWS!!! Now what???
christcansaveyou - Yanıt
There are several variants. Mine has only one screw, hidden by the battery compartment label, near the + terminal
Robert Reite - Yanıt
The most common problem with this mouse is dust and dirt getting in the optical encoder for the wheel.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 36
Son 30 gün: 155
Her zaman: 22,917
