Ana içeriğe geç
Logitech M325 Scroll Wheel Replacement
Neye ihtiyacın var
  1. Logitech M325 Scroll Wheel Replacement, Scroll Wheel: adım 1, 1 resimden 1.
    • Caution: Before you begin, ensure that the mouse is powered off (red color displayed on the switch). The switch can be found at the bottom of the mouse.
    • Remove the battery cover from the bottom of the mouse by sliding downwards.
  2. Logitech M325 Scroll Wheel Replacement: adım 2, 2 resimden 1. Logitech M325 Scroll Wheel Replacement: adım 2, 2 resimden 2.
    • Lift out the AA battery.
    • Remove the USB adapter.
  3. Logitech M325 Scroll Wheel Replacement: adım 3, 1 resimden 1.
    • Peel off the sticker in the battery compartment to reveal the screw underneath.
  4. Logitech M325 Scroll Wheel Replacement: adım 4, 2 resimden 1. Logitech M325 Scroll Wheel Replacement: adım 4, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the 5 mm screw in the battery compartment.
  5. Logitech M325 Scroll Wheel Replacement: adım 5, 2 resimden 1. Logitech M325 Scroll Wheel Replacement: adım 5, 2 resimden 2.
    • Slide the lower case downwards and separate the top case from the main mouse body by lifting it off.
  6. Logitech M325 Scroll Wheel Replacement: adım 6, 2 resimden 1. Logitech M325 Scroll Wheel Replacement: adım 6, 2 resimden 2.
    • Use a pry tool to unclip the scroll wheel from the PCB by pushing the clip out of the holder.
    • Remove the scroll wheel by lifting it up.
  7. Logitech M325 Scroll Wheel Replacement: adım 7, 2 resimden 1. Logitech M325 Scroll Wheel Replacement: adım 7, 2 resimden 2.
    • Align the replacement in the same position as the old scroll wheel.
    • Push down and clip in the scroll wheel.
  8. Logitech M325 Scroll Wheel Replacement: adım 8, 3 resimden 1. Logitech M325 Scroll Wheel Replacement: adım 8, 3 resimden 2. Logitech M325 Scroll Wheel Replacement: adım 8, 3 resimden 3.
    • Align the top housing clips with the mouse body clip openings.
    • Slide top housing back onto mouse by pushing it in.
Sonuç
To reassemble your device, follow steps 1-4 in reverse order.
Bir başkası bu kılavuzu tamamladı.
mykayat_YU
157 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 37
Her zaman: 368
