Giriş
Taking the outer shell off is very easy and all of the internals are visible when it is removed.
Parçalar
  1. Remove the battery hatch and batteries.
    • Remove the battery hatch and batteries.
  2. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  3. Remove the single Phillips screw located between the battery sockets.
    • Remove the single Phillips screw located between the battery sockets.
  4. Lift the rear of the top case of the mouse and slide forward. It should be fairly easy to release.
    • Lift the rear of the top case of the mouse and slide forward. It should be fairly easy to release.
Sonuç
4 başka kişi bu kılavuzu tamamladı.
Anna Sweetnam
232 İtibar
1 Kılavuz yazıldı
3 Yorum
I got to step 3. where is step 4?
hawaii50 - Yanıt
What are you trying to do? All of the innards are available once step 3 is complete.
Anna Sweetnam - Yanıt
Hi, just to say that its a utility named ProxyTool from Logitech that can be used to adjust the behavior of hand detection feature. here you go the file: ftp://ftp.logitech.com/pub/techsupport/m... or https://www.dropbox.com/s/z1rq7s6wzt4ohu...
You can literaly disable the Couch Mouse M515 hand proximity sensor
Luis Frederico - Yanıt
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 15
Son 30 Gün: 76
Her zaman: 3,281
