Ana içeriğe geç
Logitech M705 Button Failure Fix
Neye ihtiyacın var
  1. Logitech M705 Button Failure Fix, Dissassembly and problem identification: adım 1, 2 resimden 1. Logitech M705 Button Failure Fix, Dissassembly and problem identification: adım 1, 2 resimden 2.
    • Follow the teardown guide to disassemble the mouse
    • The pad in the upper shell of the mouse that presses on the microswitch has worn , circled red in the photograph. Comapre the wear on this side with the lower level of wear in the equivalent part for the right hand mouse on the left side of the photograph. A close up of the worn part is shown in thhe second photogrpah
    FixBot'a Sor
    Yorum Ekle
  2. Logitech M705 Button Failure Fix, Use of insulation tape to resolve problem: adım 2, 1 resimden 1.
    • Use electrical insulation tape (blue in the photographs) to build up the level of the worn pad. Here I've used four layers
    • Then reassemble the mouse
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, reverse the dissasembly process as per the Teardown Guide.
Bir başkası bu kılavuzu tamamladı.
Nick Knows
115 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
This fixed an issue for me where the mouse buttons were bouncing (double clicking when trying to hold the button down).
user5219 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 44
Her zaman: 598
