Ana içeriğe geç
Logitech MBJ58 Mouse Button Replacement
Neye ihtiyacın var
    1. Logitech MBJ58 Mouse Button Replacement, Mouse button: adım 1, 1 resimden 1.
      • Unfortunately, the left mouse button was 2x "sucked out" (button & the plastic pin over it)
      • Solution: Swap the button on the left with the mouse wheel button and - n small piece of office clip - for reinforcement - melt into the bottom of the pen.
      • YahooOoO - Looift widerer! Addendum: "mouse wheel click" Works by the way also - because there small springs ensure that the button does not "stick" in the pressed state
      FixBot'a Sor
      Yorum Ekle
      • Loosen the Phillips screw in the bottom.
      FixBot'a Sor
      Yorum Ekle
      • The plastic holder of the mouse buttons is loosened by carefully pressing the two plastic closures in the middle.
      • The motherboard is just plugged in and can be carefully removed forwards and upwards.
      FixBot'a Sor
      Yorum Ekle
      • Sensibly, first clean everything (dry).
      • Now click the button for "Links" with the button below the mouse wheel. The solder joints are huge and easy to get even for beginners.
      FixBot'a Sor
      Yorum Ekle
      • Everything should click together again and screws can be screwed back in. -> Loooift.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Repeat the steps in reverse order to reassemble your device.
Bir başkası bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
de en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Tho. Hummet
121 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 37
Her zaman: 729
