Ana içeriğe geç
Logitech MBJ58 Mouse Buttons Replacement
Neye ihtiyacın var
  1. Logitech MBJ58 Mouse Buttons Replacement, Top cover: adım 1, 1 resimden 1.
    • Hold the mouse so that the bottom is facing up.
    • Remove the single Phillips #1 screw from the bottom half of the mouse.
    FixBot'a Sor
    Yorum Ekle
  2. Logitech MBJ58 Mouse Buttons Replacement: adım 2, 2 resimden 1. Logitech MBJ58 Mouse Buttons Replacement: adım 2, 2 resimden 2.
    • Place the mouse so that the bottom is resting against a hard surface.
    • Lift the top cover of the mouse gently, and remove it.
    FixBot'a Sor
    Yorum Ekle
  3. Logitech MBJ58 Mouse Buttons Replacement, Buttons: adım 3, 2 resimden 1. Logitech MBJ58 Mouse Buttons Replacement, Buttons: adım 3, 2 resimden 2.
    • Locate the two tabs that are protruding from the button assembly.
    • Be careful not to break either of the two tabs by squeezing too hard.
    • Pinch the tabs together to free the buttons.
    FixBot'a Sor
    Yorum Ekle
  4. Logitech MBJ58 Mouse Buttons Replacement: adım 4, 2 resimden 1. Logitech MBJ58 Mouse Buttons Replacement: adım 4, 2 resimden 2.
    • Remove the button assembly from the top cover by flipping the top cover upside down and pulling the button assembly downward and away from the top cover.
    • Slide the button assembly out from the top cover through the opening.
    • When fully disassembled, the top cover and the button assembly should look like this.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Maximilian Betkowski
238 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-14, Forte Winter 2013 Cal Poly, Team 5-14, Forte Winter 2013 üyesi
CPSU-FORTE-W13S5G14
5 Üyeler
23 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 29
Her zaman: 3,439
