Ana içeriğe geç
Logitech MBJ58 Mouse Support Spring Replacement
Neye ihtiyacın var
    1. Logitech MBJ58 Mouse Support Spring Replacement, Top cover: adım 1, 1 resimden 1.
      • Hold the mouse so that the bottom is facing up.
      • Remove the single Phillips #1 screw from the bottom half of the mouse.
      FixBot'a Sor
      Yorum Ekle
    2. Logitech MBJ58 Mouse Support Spring Replacement: adım 2, 2 resimden 1. Logitech MBJ58 Mouse Support Spring Replacement: adım 2, 2 resimden 2.
      • Place the mouse so that the bottom is resting against a hard surface.
      • Lift the top cover of the mouse gently, and remove it.
      FixBot'a Sor
      Yorum Ekle
    1. Logitech MBJ58 Mouse Support Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: adım 3, 3 resimden 1. Logitech MBJ58 Mouse Support Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: adım 3, 3 resimden 2. Logitech MBJ58 Mouse Support Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: adım 3, 3 resimden 3.
      • Locate the scroll wheel on the mouse.
      • Grab the scroll wheel with your thumb and index finger.
      • Gently lift up, to remove the scroll wheel from the mouse.
      FixBot'a Sor
      Yorum Ekle
    1. Logitech MBJ58 Mouse Support Spring Replacement, Support Spring: adım 4, 2 resimden 1. Logitech MBJ58 Mouse Support Spring Replacement, Support Spring: adım 4, 2 resimden 2.
      • Locate the spring on the scroll wheel, and carefully remove the spring.
      FixBot'a Sor
      Yorum Ekle
    2. Logitech MBJ58 Mouse Support Spring Replacement, Attaching the New Spring: adım 5, 2 resimden 1. Logitech MBJ58 Mouse Support Spring Replacement, Attaching the New Spring: adım 5, 2 resimden 2.
      • Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
      FixBot'a Sor
      Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Conor Whatley
510 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-14, Forte Winter 2013 Cal Poly, Team 5-14, Forte Winter 2013 üyesi
CPSU-FORTE-W13S5G14
5 Üyeler
23 adet Kılavuz yazıldı
1Rehber Yorum
The thing with the spring - still in 2024 helpful!
Thanks a lot! :-)
Michaela Meyer - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 20
Son 30 gün: 64
Her zaman: 5,239
