Ana içeriğe geç
Logitech MX Anywhere 2 Mouse Feet Replacement
Neye ihtiyacın var
  1. Logitech MX Anywhere 2 Mouse Feet Replacement, Soften the mouse feet adhesive: adım 1, 2 resimden 1. Logitech MX Anywhere 2 Mouse Feet Replacement, Soften the mouse feet adhesive: adım 1, 2 resimden 2.
    • Flip the mouse's power switch into the OFF position, unplug any cables, and flip it over so the feet are facing up.
    • The unique shape of some mice can prevent them from laying flat. If you need to, lay your mouse on a soft towel to prevent wobble.
    • If you're planning to reuse your existing mouse feet, note that the adhesive needs to be thoroughly heated for them to be cleanly removed.
    • Heat an iOpener and apply it to the mouse feet for about two minutes.
    • Alternatively, you can use a hair dryer to soften the mouse feet adhesive.
    • When using a hair dryer, don't heat the feet for more than a couple seconds at a time—anything hotter than just warm to the touch risks melting or warping the plastic lower case.
  2. Logitech MX Anywhere 2 Mouse Feet Replacement, Separate the mouse foot adhesive: adım 2, 3 resimden 1. Logitech MX Anywhere 2 Mouse Feet Replacement, Separate the mouse foot adhesive: adım 2, 3 resimden 2. Logitech MX Anywhere 2 Mouse Feet Replacement, Separate the mouse foot adhesive: adım 2, 3 resimden 3.
    • Insert an opening pick between a mouse foot and the lower case.
    • Go slowly, and make sure the pick slides underneath both the foot and its adhesive pad. These layers separate easily.
    • If you plan on reusing your mouse feet, be careful not to crease them or separate them from their adhesive pads.
    • Slide your pick under the foot to separate its adhesive until you can grab it with your fingers.
  3. Logitech MX Anywhere 2 Mouse Feet Replacement, Remove the mouse foot: adım 3, 2 resimden 1. Logitech MX Anywhere 2 Mouse Feet Replacement, Remove the mouse foot: adım 3, 2 resimden 2.
    • Peel up and remove the mouse foot.
  4. Logitech MX Anywhere 2 Mouse Feet Replacement, Remove the remaining mouse feet: adım 4, 3 resimden 1. Logitech MX Anywhere 2 Mouse Feet Replacement, Remove the remaining mouse feet: adım 4, 3 resimden 2. Logitech MX Anywhere 2 Mouse Feet Replacement, Remove the remaining mouse feet: adım 4, 3 resimden 3.
    • Repeat the previous two steps to remove the remaining mouse feet.
  5. Logitech MX Anywhere 2 Mouse Feet Replacement, Reassembly information: adım 5, 3 resimden 1. Logitech MX Anywhere 2 Mouse Feet Replacement, Reassembly information: adım 5, 3 resimden 2. Logitech MX Anywhere 2 Mouse Feet Replacement, Reassembly information: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • For installing new mouse feet or reusing your old ones:
    • Use a pair of tweezers or a spudger to remove any large chunks of leftover adhesive.
    • Thoroughly clean the bottom of the mouse with isopropyl alcohol and a lint-free of microfiber cloth. Allow the surface to dry completely.
    • Peel your new mouse feet away from their adhesive liners and press them firmly into place.
Sonuç
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Clay Eickemeyer
67.336 İtibar
453 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
136 Üyeler
17.430 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 25
Her zaman: 633
