Ana içeriğe geç
Logitech MX Anywhere 3 for Mac Mouse Feet Replacement
Neye ihtiyacın var
  1. Logitech MX Anywhere 3 for Mac Mouse Feet Replacement, Soften the mouse feet adhesive: adım 1, 2 resimden 1. Logitech MX Anywhere 3 for Mac Mouse Feet Replacement, Soften the mouse feet adhesive: adım 1, 2 resimden 2.
    • Flip the mouse's power switch into the OFF position, unplug any cables, and flip it over so the feet are facing up.
    • The unique shape of some mice can prevent them from laying flat. If you need to, lay your mouse on a soft towel to prevent wobble.
    • If you're planning to reuse your existing mouse feet, note that the adhesive needs to be thoroughly heated for them to be cleanly removed.
    • Heat an iOpener and apply it to the mouse feet for about two minutes.
    • Alternatively, you can use a hair dryer to soften the mouse feet adhesive.
    • When using a hair dryer, don't heat the feet for more than a couple seconds at a time—anything hotter than just warm to the touch risks melting or warping the plastic lower case.
  2. Logitech MX Anywhere 3 for Mac Mouse Feet Replacement, Disassembly information: adım 2, 2 resimden 1. Logitech MX Anywhere 3 for Mac Mouse Feet Replacement, Disassembly information: adım 2, 2 resimden 2.
    • There are small gaps in the rims surrounding each foot. This is where to place the tool in the next step.
  3. Logitech MX Anywhere 3 for Mac Mouse Feet Replacement, Remove the feet: adım 3, 3 resimden 1. Logitech MX Anywhere 3 for Mac Mouse Feet Replacement, Remove the feet: adım 3, 3 resimden 2. Logitech MX Anywhere 3 for Mac Mouse Feet Replacement, Remove the feet: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Push the tip of an opening pick underneath the mouse foot adhesive, into the gap in the rim.
    • Go slowly, and make sure the pick slides underneath both the foot and its adhesive pad. These layers separate easily.
    • If you plan on reusing your mouse feet, be careful not to crease them or separate them from their adhesive pads.
    • Slide your pick under the foot to separate its adhesive until you can grab it with your fingers.
    • Repeat to remove the three remaining mouse feet.
    • For installing new mouse feet or reusing your old ones:
    • Use a pair of tweezers or a spudger to remove any large chunks of leftover adhesive. Thoroughly clean the bottom of the mouse with isopropyl alcohol and a lint-free of microfiber cloth. Allow the surface to dry completely.
    • Peel your new mouse feet away from their adhesive liners and press them firmly into place.
Sonuç
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Bir başkası bu kılavuzu tamamladı.
Clay Eickemeyer
82.642 İtibar
455 adet Kılavuz yazıldı
Ekip
Guide Team Guide Team üyesi
Staff
9 Üyeler
11.554 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 20
Her zaman: 358
