Ana içeriğe geç
Logitech MX Ergo Disassembly
Neye ihtiyacın var
  1. Logitech MX Ergo Disassembly, Logitech MX Ergo: adım 1, 1 resimden 1.
    • Remove six T6 screws from the bottom
    A T6 in a bit driver will not work here. The two screws around the ball are recessed in the holes and the holes are too narrow for a 4mm bit to fit and reach the screw head. You need a dedicated T6 screwdriver with a "precision" diameter shaft to remove those.
    alan - Yanıt
    of the six torx screws, two have narrow, deep holes - my ifixit bits barely fit, scraping away some of the case as I went. Very minor cosmetic damage.
    Zachary Coffin - Yanıt
  2. Logitech MX Ergo Disassembly: adım 2, 1 resimden 1.
    • Slide a prying tool under the rightmost button and follow the seam back till the top half unclips
    Once you open the cover, you can skip straight until step #13.
    Eiti - Yanıt
    Most helpful part here - where to pry to get the shell apart without breaking anything.
  3. Logitech MX Ergo Disassembly: adım 3, 1 resimden 1.
    • Carefully lift the top shell.
    • Do not remove the flap from the connector.
    • Release the flex ribbon from its socket.
    Note the dark brown part of the connector LIFTS UP, don’t try to remove it or it could break. The brown part pushes against the cable to make it snug.
    sean richards - Yanıt
    There is no need to disconnect the ribbon to clean the mouse wheel. Just take the cover and put it outside face down, like opening a clamshell towards the camera in the above picture. the flex ribbon is plenty long and there is no stress on either connection.
    There is also no reason to do steps 4 through 10. They add nothing in terms of access to the wheel for cleaning.
    If you do this, you can skip to steps 11 and 12.
    alan - Yanıt
    I accidentally broke the black part that lifts up. Do you know the part number of this?
    marc1370ms - Yanıt
    I broke this black part. Does anyone know the part number?
    Irfan - Yanıt
  4. Logitech MX Ergo Disassembly: adım 4, 1 resimden 1.
    • Lever the scrollwheel sub-assembly free
    The scrub wheel has a metal lever pushing down on it, using a small spring. Those who have used other Logitech mice, such as G700s, would find that because of this level, the wheel doesn't rotate freely. The lever can be removed by pushing out and lifting the part pushed by the spring and gently and carefully removing that spring. Then the lever itself can be pushed sideways out of the tiny hole, to remove it fully. Now I have a freely rotating wheel. Gives much pleasure browsing long pages of text.
    A A - Yanıt
  5. Logitech MX Ergo Disassembly: adım 5, 1 resimden 1.
    • Unplug the battery from the mainboard, carefully lifting the plug marked red.
    • Unscrew the three screws holding the battery submodule.
  6. Logitech MX Ergo Disassembly: adım 6, 2 resimden 1. Logitech MX Ergo Disassembly: adım 6, 2 resimden 2.
    • Unscrew the bottom left screw holding down the fwd/rev buttons, lifting the assembly to the side
    • Unplug the flex ribbon indicated in blue, coming from the power board below. Remove the six screws holding the main motherboard (one indicated orange here, just out of shot).
  7. Logitech MX Ergo Disassembly: adım 7, 1 resimden 1.
    • Unscrew the three screws holding the power board i place. Take care not to loose the power switch below as you take the last bits apart.
    • These three screws are a bit shorter than the rest, so keep them separate
  8. Logitech MX Ergo Disassembly: adım 8, 2 resimden 1. Logitech MX Ergo Disassembly: adım 8, 2 resimden 2.
    • There you go, all disassembled. Now remove spilled coffee.
  9. Logitech MX Ergo Disassembly, Disassembly of top half: adım 9, 3 resimden 1. Logitech MX Ergo Disassembly, Disassembly of top half: adım 9, 3 resimden 2. Logitech MX Ergo Disassembly, Disassembly of top half: adım 9, 3 resimden 3.
    • The right click lever comes out after the bracket covering the ribbon cable
    • The Right click lever comes out through the front/top of the mouse
    • Then the circuit boards can be removed
  10. Logitech MX Ergo Disassembly: adım 10, 3 resimden 1. Logitech MX Ergo Disassembly: adım 10, 3 resimden 2. Logitech MX Ergo Disassembly: adım 10, 3 resimden 3.
    • Under the circuit boards there is three piece that need to come out next
    • The first has one screw and two clear pieces that transmit the light from the circuit board to the outside of the mouse and hole to allow another to pass through it
    • Then the computer selector switch lever can come out the front/top of the mouse
    • After that the connecting light indicator transmitter will fall out and the left click lever can be removed
    Thanks! I did that for clean my one!
    Alexander Fedyunin - Yanıt
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
Jørn-Stian
434 İtibar
1 Kılavuz yazıldı
20Kılavuz Yorumları
Thank you for the guide. The opening was hilarious— a picture says 1000 words.
I wanted to add a note that you need to use a T6 with a very long neck like the one iFixit offers for sale; an ordinary bit with a ~ 1/2” or ~1 cm long head will not be able to reach the two next to the opening to the thumb ball.
Allison Adz - Yanıt
I had the same issue as you. My left click got damaged somehow and wouldn’t “return” when I clicked it. Opened it up, took both springs out and compared them. Looks like the left click spring got bent somehow. Straightened it up a bit and put it back in, seems to work perfectly now! I was going to buy a new one, but now I don’t have to. Thanks for the guide and +1 for iFixIt!!!
B T - Yanıt
Hi,
My ergo fell down and I am unable to change the bluetooth selector : it is stuck on « 2 » and my pc does not see he mouse anymore.
Any idea how I could fix this ?
Thanks
Raymond Ghysels - Yanıt
tinker with the board in step 9. the button for bluetooth selection is on that board.
Frank -
Any updates on this? Having the same issue, but stuck on 1, and won't enter pairing mode either. Removed and cleaned with IPA, hoping that works. Any idea where the actual bluetooth module is located on the board(s)? Nothing appears loose but don't get a connection with a new receiver, via cable, or bluetooth to anything that should be able to see the device. Thanks in advance.
Ricky VanWert -
I have same issue as well. 1-2 button stuck on one or the other and blinking. Early on I had success cleaning the ribbon contacts and switch. after about 5x that no longer works. I originally had 1 pc using Logi unifying rcvr and the other with BT. Switch both to Logi to see if that would help - it didn't. Pretty sure its a bad switch - one of the smaller metal ones. I suppose next step is to reflow and then look for a replacement switch, or a parts doner mouse.
Mike Clark -
hi, are the omron switches of the left and right buttons soldered, or are they interlocking?
giat - Yanıt
@gullit left and right buttons are soldered. only normal open and common are used, NormalClosed is soldered but not connected. I just replaced them with silent switches. thanks to this guide.
Frank - Yanıt
Are the Schematics for the PCB available?
I replaced the switches but now the right click does not work anymore.
When I press the right click button, I can hear the switch click, but nothing happens on the screen.
Akhil - Yanıt
I had the same issue on a left switch after replaced it with a longer life (D2FC-F-K (50M), Further checked with multimeter for continuous of signal from the switch's pin to its circuit then found that it was my poor soldering at the switch's pin. You may encounter the same issue as mine...Hope this helps.
Yos Sufficiency -
Thank you so much for this. I find the click sensitivity on the right button to be obscenely light. So much so that I experience 15-20 unintentional clicks per hour, just from resting my hand on it. I'm going to open this sucker up and carefully, delicately, bend the crap out of those springs.
Ron Moses - Yanıt
Thank you so much for this. I too was having issues with the left click button being unresponsive/going back to it’s original setting. Adjusted the springs after performing the top disassembly and my mouse clicks like normal again.
Michael Li - Yanıt
The buttons (which start to get a bit iffy after a year or so of use) are these - https://www.amazon.co.uk/D2FC-F-7N-Switc.... Going to find out how tricky they are to desolder as I've an old MX Ergo and a new one, so I can practice the job. This disassembly guide was helpful, especially as I got a little stuck around the roller assembly, helpful to see where leverage could go.
Danny Staple - Yanıt
spare parts available? I can't find a wheel (broken by a fall)
jo buelens - Yanıt
mouse button springs? Where can I get them?
Ben Bass - Yanıt
i have to substitute both microswitch of mouse left and right botons.
case you know the switch part number, please let me know it.
WILLLIAM FRANÇOIS DE FARIA JR - Yanıt
I accidentally broke the brown part that lifts up in Step 3. Does anyone know the part number of this?
marc1370ms - Yanıt
My left button‘s spring is missing.
Where to get replacement springs?
Gunni - Yanıt
Is there a replacement for the rubbery cover? Mine has started to "rot" but the mouse works great. So was considering to replace that part.
Bruno Cheganças - Yanıt
Great guide!
Mine has a cracked inductor at L3 which was whining really loudly, so I blobbed it with hot glue and now it's perfectly quiet.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 51
Son 30 gün: 348
Her zaman: 13,622
