Ana içeriğe geç
Logitech MX Ergo Scroll Wheel (fixing slippage)
Neye ihtiyacın var
  1. Logitech MX Ergo Scroll Wheel (fixing slippage), Logitech MX Ergo: adım 1, 1 resimden 1.
    • Remove six T6 screws from the bottom
    A T6 in a bit driver will not work here. The two screws around the ball are recessed in the holes and the holes are too narrow for a 4mm bit to fit and reach the screw head. You need a dedicated T6 screwdriver with a "precision" diameter shaft to remove those.
    alan - Yanıt
    of the six torx screws, two have narrow, deep holes - my ifixit bits barely fit, scraping away some of the case as I went. Very minor cosmetic damage.
    Zachary Coffin - Yanıt
  2. Logitech MX Ergo Scroll Wheel (fixing slippage): adım 2, 1 resimden 1.
    • Slide a prying tool under the rightmost button and follow the seam back till the top half unclips
    Once you open the cover, you can skip straight until step #13.
    Eiti - Yanıt
    Most helpful part here - where to pry to get the shell apart without breaking anything.
  3. Logitech MX Ergo Scroll Wheel (fixing slippage): adım 3, 1 resimden 1.
    • Carefully lift the top shell.
    • Do not remove the flap from the connector.
    • Release the flex ribbon from its socket.
    Note the dark brown part of the connector LIFTS UP, don’t try to remove it or it could break. The brown part pushes against the cable to make it snug.
    sean richards - Yanıt
    There is no need to disconnect the ribbon to clean the mouse wheel. Just take the cover and put it outside face down, like opening a clamshell towards the camera in the above picture. the flex ribbon is plenty long and there is no stress on either connection.
    There is also no reason to do steps 4 through 10. They add nothing in terms of access to the wheel for cleaning.
    If you do this, you can skip to steps 11 and 12.
    alan - Yanıt
    I accidentally broke the black part that lifts up. Do you know the part number of this?
    marc1370ms - Yanıt
    I broke this black part. Does anyone know the part number?
    Irfan - Yanıt
  4. Logitech MX Ergo Scroll Wheel (fixing slippage): adım 4, 1 resimden 1.
    • Lever the scrollwheel sub-assembly free
    The scrub wheel has a metal lever pushing down on it, using a small spring. Those who have used other Logitech mice, such as G700s, would find that because of this level, the wheel doesn't rotate freely. The lever can be removed by pushing out and lifting the part pushed by the spring and gently and carefully removing that spring. Then the lever itself can be pushed sideways out of the tiny hole, to remove it fully. Now I have a freely rotating wheel. Gives much pleasure browsing long pages of text.
    A A - Yanıt
  5. Logitech MX Ergo Scroll Wheel (fixing slippage): adım 5, 1 resimden 1.
    • Unplug the battery from the mainboard, carefully lifting the plug marked red.
    • Unscrew the three screws holding the battery submodule.
  6. Logitech MX Ergo Scroll Wheel (fixing slippage): adım 6, 2 resimden 1. Logitech MX Ergo Scroll Wheel (fixing slippage): adım 6, 2 resimden 2.
    • Unscrew the bottom left screw holding down the fwd/rev buttons, lifting the assembly to the side
    • Unplug the flex ribbon indicated in blue, coming from the power board below. Remove the six screws holding the main motherboard (one indicated orange here, just out of shot).
  7. Logitech MX Ergo Scroll Wheel (fixing slippage): adım 7, 1 resimden 1.
    • Unscrew the three screws holding the power board i place. Take care not to loose the power switch below as you take the last bits apart.
    • These three screws are a bit shorter than the rest, so keep them separate
  8. Logitech MX Ergo Scroll Wheel (fixing slippage): adım 8, 2 resimden 1. Logitech MX Ergo Scroll Wheel (fixing slippage): adım 8, 2 resimden 2.
    • There you go, all disassembled. Now remove spilled coffee.
  9. Logitech MX Ergo Scroll Wheel (fixing slippage), Disassembly of top half: adım 9, 3 resimden 1. Logitech MX Ergo Scroll Wheel (fixing slippage), Disassembly of top half: adım 9, 3 resimden 2. Logitech MX Ergo Scroll Wheel (fixing slippage), Disassembly of top half: adım 9, 3 resimden 3.
    • The right click lever comes out after the bracket covering the ribbon cable
    • The Right click lever comes out through the front/top of the mouse
    • Then the circuit boards can be removed
  10. Logitech MX Ergo Scroll Wheel (fixing slippage): adım 10, 3 resimden 1. Logitech MX Ergo Scroll Wheel (fixing slippage): adım 10, 3 resimden 2. Logitech MX Ergo Scroll Wheel (fixing slippage): adım 10, 3 resimden 3.
    • Under the circuit boards there is three piece that need to come out next
    • The first has one screw and two clear pieces that transmit the light from the circuit board to the outside of the mouse and hole to allow another to pass through it
    • Then the computer selector switch lever can come out the front/top of the mouse
    • After that the connecting light indicator transmitter will fall out and the left click lever can be removed
    Thanks! I did that for clean my one!
    Alexander Fedyunin - Yanıt
  11. Logitech MX Ergo Scroll Wheel (fixing slippage), Remove dust/filth: adım 11, 1 resimden 1.
    • With the cover open, look at the scroll wheel on the side that has a hollow central area and roll the wheel. You should look for any dirt/filth that may have accumulated on this inner side of the wheel in the form of a little ball that interferes with the sensors (see image on next step).
  12. Logitech MX Ergo Scroll Wheel (fixing slippage): adım 12, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Carefully remove it using tweezers, so you don't bump the assembly out of alignment.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Eiti
177 İtibar
1 Kılavuz yazıldı
5Kılavuz Yorumları
Before going to all that work, I tried using a can of air to forcefully blow into the gap on each side of the scroll wheel. I don't know if it got any lint out, but it started working perfectly again without having to disassemble it.
Robert Fraser - Yanıt
This is much more complex than it needs to be. Do step 1, then step 2, and then instead of step 3 you put the top half of the mouse to the right side of the mouse with the top on the table, like opening a clamshell to the right. The ribbon to the top half is plenty long, and you have full access to the scroll wheel for cleaning and you can skip to steps 11 and 12.
Vacuum and forced air didn't work for me, as my 6+ year old mouse had a bunch of hair and lint trapped in the mechanism, but with tweezers I was able to extract enough that the mouse works great again.
Further note that step 1 will not work with a normal T6 bit driver, as two of the screws are recessed pretty far, screw holes are too narrow for a 4mm bit to fit. Luckily, I had a dedicated T6 driver with a narrow shaft that fit in.
alan - Yanıt
I completely agree with you @alan9532 . Someone added a bunch of unnecessary steps after I created the guide.
We just need to remove the screws, lift the cover and clean the wheel, that's it.
I tried removing the unnecessary steps. I hope they don't add them back again!
Thank you for pointing it out.
Eiti -
Hi, what parts need replacing if cleaning the wheel and housing has no effect? My mouse can scroll back, but not forwards anymore.
Cindy du Plessis - Yanıt
Hi @cindyatay
By your message, it isn't clear if the wheel stopped "mechanically" rolling in one direction or if it doesn't respond (on the screen cursor) to the movement on the wheel.
If it is a mechanical problem, I would check if the torsion spring (the metal part near the wheel) is correctly nested.
Good luck!
Eiti -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 24
Son 30 gün: 174
Her zaman: 2,359
