Giriş
Follow this guide to replace worn-out or damaged feet (also known as skates, glides, slides, or pads) on your Logitech MX Keys wireless keyboard.
Neye ihtiyacın var
Slide the keyboard's power switch into the OFF position.
Unplug all cables from your keyboard.
Lay your keyboard down with the feet facing up on a clean work surface.
Bu adımda kullanılan alet:Tesa 61395 Tape$2.95
Use a pair of angled tweezers to peel up and remove all the plastic film from the foot recesses.
If you're installing new feet, remove them from their backing and firmly press them into place.
If you're reusing the feet, use a strip of double-sided tape to secure them in their recesses.
2 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
Where do you buy replacement 'feet' for the MX Keys?
Hi, mooie uitleg.
Vraagje: Heeft iemand een idee waar ik de voetjes van een mx toetsenbord kan kopen? Bij mij bord zijn er twee uitgevallen.
En een geweldig initiatief is ifixit!
Groet Henk Volkers
