Ana içeriğe geç
Logitech MX Master 3 for Mac Mouse Feet Replacement
Neye ihtiyacın var
  1. Logitech MX Master 3 for Mac Mouse Feet Replacement, Soften the mouse feet adhesive: adım 1, 3 resimden 1. Logitech MX Master 3 for Mac Mouse Feet Replacement, Soften the mouse feet adhesive: adım 1, 3 resimden 2. Logitech MX Master 3 for Mac Mouse Feet Replacement, Soften the mouse feet adhesive: adım 1, 3 resimden 3.
    • Flip the mouse's power switch into the OFF position, unplug any cables, and flip it over so the feet are facing up.
    • The unique shape of some mice can prevent them from laying flat. If you need to, lay your mouse on a soft towel to prevent wobble.
    • If you're planning to reuse your existing mouse feet, note that the adhesive needs to be thoroughly heated for them to be cleanly removed.
    • Heat an iOpener and apply it to each of the mouse feet for about one minute each.
    • Alternatively, you can use a hair dryer to soften the mouse feet adhesive.
    • When using a hair dryer, don't heat the feet for more than a couple seconds at a time—anything hotter than just warm to the touch risks melting or warping the plastic lower case.
    • The information sticker adhesive may soften during this step, but you don't need to remove it.
  2. Logitech MX Master 3 for Mac Mouse Feet Replacement, Separate the mouse foot adhesive: adım 2, 3 resimden 1. Logitech MX Master 3 for Mac Mouse Feet Replacement, Separate the mouse foot adhesive: adım 2, 3 resimden 2. Logitech MX Master 3 for Mac Mouse Feet Replacement, Separate the mouse foot adhesive: adım 2, 3 resimden 3.
    • Slide an opening pick under an edge of the left mouse foot.
    • Go slowly, and make sure the pick slides underneath both the foot and its adhesive pad. These layers separate easily.
    • If you plan on reusing your mouse feet, be careful not to crease them or separate them from their adhesive pads.
    • If the foot feels stuck, apply more heat before continuing.
    • Slide your pick under the foot to separate its adhesive until you can grab it with your fingers.
    • Peel up and remove the left mouse foot.
  3. Logitech MX Master 3 for Mac Mouse Feet Replacement, Remove the right and rear mouse feet: adım 3, 2 resimden 1. Logitech MX Master 3 for Mac Mouse Feet Replacement, Remove the right and rear mouse feet: adım 3, 2 resimden 2.
    • Repeat the previous two steps to remove the right and the rear mouse feet.
  4. Logitech MX Master 3 for Mac Mouse Feet Replacement, Reassembly information: adım 4, 3 resimden 1. Logitech MX Master 3 for Mac Mouse Feet Replacement, Reassembly information: adım 4, 3 resimden 2. Logitech MX Master 3 for Mac Mouse Feet Replacement, Reassembly information: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • If the adhesive separated from the foot:
    • Slide the flat end of a spudger under an edge of the adhesive. If the adhesive seems stuck, you may need to heat the adhesive further.
    • Use a pair of tweezers or a spudger to remove any large chunks of leftover adhesive.
    • For installing new mouse feet or reusing your old ones:
    • Thoroughly clean the bottom of the mouse with isopropyl alcohol and a lint-free of microfiber cloth. Allow the surface to dry completely.
    • Peel your new mouse feet away from their adhesive liners and press them firmly into place.
  5. Logitech MX Master 3 for Mac Mouse Feet Replacement, Remove the front mouse foot: adım 5, 1 resimden 1.
    • Remove the front mouse foot.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Adam O'Camb
210.307 İtibar
416 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 23
Son 30 gün: 105
Her zaman: 6,359
