Ana içeriğe geç
Logitech Mouse MX1000 Disassembly
Neye ihtiyacın var
  1. Logitech Mouse MX1000 Disassembly, Open the housing: adım 1, 2 resimden 1. Logitech Mouse MX1000 Disassembly, Open the housing: adım 1, 2 resimden 2.
    • There are four screws hidden on the bottom part of the mouse. Two are below the sticker, the last two are below the bottom pads.
  2. Logitech Mouse MX1000 Disassembly, Disconnect the cables: adım 2, 3 resimden 1. Logitech Mouse MX1000 Disassembly, Disconnect the cables: adım 2, 3 resimden 2. Logitech Mouse MX1000 Disassembly, Disconnect the cables: adım 2, 3 resimden 3.
    • Once the scews removed, carefully open the housing. Some cables hold both pieces together
    • First remove the tricolor battery cable
    • Then carefully remove the ribbon cable
  3. Logitech Mouse MX1000 Disassembly, Remove the battery: adım 3, 1 resimden 1.
    • To remove the battery cover, two more screws need to be removed.
    • The battery is then held in place with a sticker within the housing.
  4. Logitech Mouse MX1000 Disassembly, Remove the board from the housing: adım 4, 3 resimden 1. Logitech Mouse MX1000 Disassembly, Remove the board from the housing: adım 4, 3 resimden 2. Logitech Mouse MX1000 Disassembly, Remove the board from the housing: adım 4, 3 resimden 3.
    • Remove the three screws (red circles) holding the board in place
    • Remove the wheel and the white piece of plastic holding it down
    • A clip (yellow circle) further holds it down
    • Finally you need to unsolder the charging pads (orange circles)
  5. Logitech Mouse MX1000 Disassembly, You are done: adım 5, 1 resimden 1.
    • Congrats, you now fully dissassembled your logitech mouse!
Sonuç
lija31415
313 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 51
Her zaman: 1,044
