Ana içeriğe geç
Logitech Performance MX Disassembly
    1. Logitech Performance MX Disassembly, Remove the Mouse Feet: adım 1, 2 resimden 1. Logitech Performance MX Disassembly, Remove the Mouse Feet: adım 1, 2 resimden 2.
      • Peel off the three thin, plastic mouse feet on the bottom of the mouse. Make sure to carefully remove the adhesive along with the pad.
      • Use a thin flat object such as a flathead screwdriver to help remove if necessary.
      FixBot'a Sor
      Yorum Ekle
    2. Logitech Performance MX Disassembly, Remove the First Four Screws: adım 2, 2 resimden 1. Logitech Performance MX Disassembly, Remove the First Four Screws: adım 2, 2 resimden 2.
      • Using a screwdriver, unscrew the four screws that were under the mouse feet.
      • Remove the battery from the mouse if not done already.
      FixBot'a Sor
      Yorum Ekle
    3. Logitech Performance MX Disassembly, Separate the Top and Bottom: adım 3, 3 resimden 1. Logitech Performance MX Disassembly, Separate the Top and Bottom: adım 3, 3 resimden 2. Logitech Performance MX Disassembly, Separate the Top and Bottom: adım 3, 3 resimden 3.
      • Gently pull the top of the mouse off from the base, making sure the wires and components are in place.
      • Carefully pull out the white enclosure from its port to safely take the top apart from the bottom.
      FixBot'a Sor
      Yorum Ekle
    4. Logitech Performance MX Disassembly, Remove the Scroll Wheel Base: adım 4, 2 resimden 1. Logitech Performance MX Disassembly, Remove the Scroll Wheel Base: adım 4, 2 resimden 2.
      • Pull out the plastic pin in-between the scroll wheel and the battery enclosure and pull up on the scroll wheel base to remove.
      FixBot'a Sor
      Yorum Ekle
    5. Logitech Performance MX Disassembly, Unscrew for the Battery Capsule: adım 5, 2 resimden 1. Logitech Performance MX Disassembly, Unscrew for the Battery Capsule: adım 5, 2 resimden 2.
      • Remove the 2 small springs underneath the scroll wheel base.
      • Unscrew the four screws holding the battery capsule onto the PCB.
      FixBot'a Sor
      Yorum Ekle
    6. Logitech Performance MX Disassembly, Unplug the Ribbon Cable: adım 6, 2 resimden 1. Logitech Performance MX Disassembly, Unplug the Ribbon Cable: adım 6, 2 resimden 2.
      • Unplug the ribbon cable from the circuit board. Be careful to not remove the cable’s locking mechanism.
      FixBot'a Sor
      Yorum Ekle
    7. Logitech Performance MX Disassembly, Remove Scroll Wheel Support: adım 7, 2 resimden 1. Logitech Performance MX Disassembly, Remove Scroll Wheel Support: adım 7, 2 resimden 2.
      • Unscrew the four screws to take out the black scroll wheel support in the center and the two black pads that lie on both sides of the support.
      FixBot'a Sor
      Yorum Ekle
    8. Logitech Performance MX Disassembly, Pull Up Circuit Board: adım 8, 2 resimden 1. Logitech Performance MX Disassembly, Pull Up Circuit Board: adım 8, 2 resimden 2.
      • Pull the circuit board up to find the on and off switch. Take out the clear plastic bit that held the springs.
      FixBot'a Sor
      Yorum Ekle
    9. Logitech Performance MX Disassembly, Disassembly Finished!: adım 9, 1 resimden 1.
      • All parts should be visible to repair or for replacement.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Although useful, sadly this guide does not show how to disassemble the upper parts where the 3 switches for zoom, back and forward are located. Step 3 is the only place that shows this area, but only focuses on the disconnection of it.
Phil Millard - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 25
Son 30 gün: 116
Her zaman: 5,568
