Ana içeriğe geç
Bu çeviri, kaynak kılavuzdaki en son güncellemeleri yansıtmayabilir. Çeviriyi güncellemeye yardımcı olun veya kaynak kılavuzunu görüntüleyin.
Logitech Performance MX Left Click Repair
Neye ihtiyacın var
    1. Logitech Performance MX Left Click Repair, Turn off the mouse and remove the battery: adım 1, 1 resimden 1.
      • On the back of the mouse, slide the power switch so that the red area is showing to turn off the mouse. Pry open the panel on the bottom to remove the battery.
      FixBot'a Sor
      Yorum Ekle
    2. Logitech Performance MX Left Click Repair, Remove the 3 pads: adım 2, 1 resimden 1.
      • To access the screws necessary to open the mouse, you must remove the pads on the bottom of the mouse. Use a sharp tool such as an iFixit Jimmy tool or an X-acto knife to separate the pad from the case. Each pad has two layers. Ideally, both should remain attached, but this is hard to achieve.
      FixBot'a Sor
      Yorum Ekle
    3. Logitech Performance MX Left Click Repair, Remove the 4 screws: adım 3, 1 resimden 1.
      • Use a 00 Phillips-Head screwdriver to remove the screws at the bottom of the mouse.
      FixBot'a Sor
      Yorum Ekle
    4. Logitech Performance MX Left Click Repair, Remove the upper part of the mouse: adım 4, 3 resimden 1. Logitech Performance MX Left Click Repair, Remove the upper part of the mouse: adım 4, 3 resimden 2. Logitech Performance MX Left Click Repair, Remove the upper part of the mouse: adım 4, 3 resimden 3.
      • Slide the bottom laterally while lifting.
      FixBot'a Sor
      Yorum Ekle
    5. Logitech Performance MX Left Click Repair, (optional) remove the connector: adım 5, 1 resimden 1.
      • This step isn't necessary, but it makes it easier to work on the mouse.
      FixBot'a Sor
      Yorum Ekle
    6. Logitech Performance MX Left Click Repair, (optional) put a bit of tape on top of the microswitch: adım 6, 1 resimden 1.
      • This helps to avoid losing the white piece.
      FixBot'a Sor
      Yorum Ekle
    7. Logitech Performance MX Left Click Repair, Remove the multiswitch top: adım 7, 2 resimden 1. Logitech Performance MX Left Click Repair, Remove the multiswitch top: adım 7, 2 resimden 2.
      • Use your spudger to push the vertical front part of the multiswitch outwards to unhook the top part of the switch casing.
      FixBot'a Sor
      Yorum Ekle
    8. Logitech Performance MX Left Click Repair, Flatten the metallic piece: adım 8, 2 resimden 1. Logitech Performance MX Left Click Repair, Flatten the metallic piece: adım 8, 2 resimden 2.
      • Flatten the metallic piece of the multiswitch (it will probably be curved upward) until you get a neat "click" sound.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble the mouse, follow the instructions in the reverse order.
12 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
fr en
94%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Samuel Colin
717 İtibar
2 adet Kılavuz yazıldı
8Kılavuz Yorumları
merci , ca vient de sauver ma Revolution
Clement Renaut - Yanıt Paylaş
Avec plaisir. J'en suis ravi :)
Samuel Colin - Yanıt Paylaş
Thank you, this worked flawlessly. Your time and effort is well appreciated.
Kenji Lum - Yanıt Paylaş
Thank you so much. My left click often unregisters incorrectly. If not for step 7 and 8, I wouldn't have opened the multiswitch top and clean the contact point. Seems to work perfectly normal now. It'd be a waste to throw away the whole item just because of a tiny defective component. Thanks again for helping me fixed it.
Thuan Chau - Yanıt Paylaş
@Kenji @thuan: I'm glad I could help. Thanks for your comments!
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 37
Son 30 gün: 190
Her zaman: 25,659
