Ana içeriğe geç
Logitech R400 Presenter Disassembly
Neye ihtiyacın var
    1. Logitech R400 Presenter Disassembly, Remove the unnecessary parts: adım 1, 2 resimden 1. Logitech R400 Presenter Disassembly, Remove the unnecessary parts: adım 1, 2 resimden 2.
      • Remove the USB-Receiver.
      • Open the battery compartment.
      • Remove the batteries.
      FixBot'a Sor
      Yorum Ekle
    2. Logitech R400 Presenter Disassembly, Remove the sticker: adım 2, 1 resimden 1.
      • To remove the sticker that's covering the next screws, I used a small slot screwdriver and carefully inserted it at the shown position. There is a little notch here that guides you in.
      FixBot'a Sor
      Yorum Ekle
    3. Logitech R400 Presenter Disassembly, Remove 2 screws: adım 3, 1 resimden 1.
      • Below the sticker we have two Philips screws (red). Unscrew them.
      • Edit according to Simon (see comment): In the yellow slot there is a tab that is to be pushed down to unlatch it. If you insert a pick in the seam between the top and the bottom half of the device it should open easily when downward pressure is applied to the latch..
      • Now carefully pry apart the two halves of the cover, starting from the side of the battery compartment.
      FixBot'a Sor
      Yorum Ekle
    4. Logitech R400 Presenter Disassembly, Just another screw.: adım 4, 1 resimden 1.
      • The green board is where all the application logic is in, so don't scratch it.
      • There is one single screw. Unscrew it.
      • Carefully take out the green board. The connectors for the batteries are attached here, don't break them (though they are quite sturdy). Step 6 has an image how the board looks from the other side.
      FixBot'a Sor
      Yorum Ekle
    5. Logitech R400 Presenter Disassembly, Finished: adım 5, 1 resimden 1.
      • This should be the end product.
      FixBot'a Sor
      Yorum Ekle
    6. Logitech R400 Presenter Disassembly, Not actually part of the disassembly...: adım 6, 2 resimden 1. Logitech R400 Presenter Disassembly, Not actually part of the disassembly...: adım 6, 2 resimden 2.
      • The reason why I disassembled my presenter was, that the laser diode (red) did not project out of the case any more. You can clearly see the laser being at a very odd angle. I can not imagine how that happened.
      • The yellow marker shows the battery connectors you are not supposed to break in step 4.
      • In the last image you see the "fixed" laser diode. I just gently pushed it down, now it's working again.
      FixBot'a Sor
      Yorum Ekle
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
Stephan
1.373 İtibar
2 adet Kılavuz yazıldı
14Kılavuz Yorumları
excellent description. it works immediately.
wafiq shafiq - Yanıt Paylaş
well done … I did not expect to dissamble an electronic device and it is going to work again :)
god bless you mate!
Filip Liebert - Yanıt Paylaş
R800 disassembly is indeed similar, although the sticker is in two parts. The battery image should also be removed.
Dave Geerardyn - Yanıt Paylaş
Seems that Logitech has produced several generations or versions and calls them call R400. Mine looks all different inside, for example the laser diode cannot bend any longer, it has got its own bolting-down-plate and two flex cables to connect it. My PID is WD502XM. Mine was purchased in Denmark or Sweden some time in 2014 or 2015. My laser stopped working too (while the rest of the functionality is still working). How can we set up different versions on ifixit, so that we will not confuse versions and discussions/instructions? I am new here, joined today.
Martin - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 29
Son 30 gün: 113
Her zaman: 17,527
